  3. Two sdc files and one design
  • Subscribers 95
  • Views 19746
tsahi
tsahi over 17 years ago
Hi friends,
My name is Tsahi, I am electronics student and beginner in place and route field.
One of the inputs of place and route is the timing constraints (sdc file).
In our mini project there are two sdc files:
1)  Pre cts  SDC file
2) Post cts SDC file
Can someone explain me why is the reason to make to two files and not use just single constraint file.
I attached the files to one zip file in comparing to each other (the left is pre cts, on the right hand post cts) and changes are marked.
Tsahi.
sdc.zip
  • BobD
    BobD over 17 years ago
    Hi Tsahi,
    Typically, separate preCTS and postCTS files are used to adjust the values associated with "set_clock_uncertainty" and sometimes the set_min/max_delay values to account for propagated clocks.
    However, in your case (thanks for the attachment, it is very helpful) it appears that the postCTS SDC contains the following types of additions:
    1. Removal of "set_clock_transition" statements
      Removing these constraints should *not* be necessary in Encounter because
      postCTS the actual propagated clock values should override the SDC-asserted transition times.
    2. Addition of "set_propagated_clock" statements
      Encounter will automatically append "set_propagated_clock" statements for each clock tree you build within Encounter. So long as your create_clock target == your AutoCTSRootPin, manually propagating the clocks postCTS with "set_propagated_clock" statements isn't necessary. If for some reason the create_clock target does *not* align with your AutoCTSRootPin, adding set_propagated_clock statements for each logical clock is necssary and may be why these are added.
    3. A single addition of a set_clock_latency statement for one of the clocks.
      The postCTS SDC contains "set_clock_latency 2 [get_clocks wb_bus_clock]" so that the values in the postCTS file for set_min/max_delay statements are still valid when the internal clocks have been propagated.
    Hope this helps,
    Bob
  • tsahi
    Dear bob,
    Thank you for "speedy" answer.
    From your point of view :
    1) Is these really minor changes between the pre and post sdc's files ?
    2) Does these minor changes can affect the design (any design), if it does what is it
    meaning (in general of course)?
    Thank you for the kind attitude.
    Tsahi.
  • BobD
    You're welcome!
    The first 2 items are minor (or perhaps meaningless depending on the caveats I mentioned in italics above). The 3rd item (set_clock_latency) is actually quite important and if not included it would invalidate your IO timing.
    Bob
  • Kari
    Kari over 17 years ago
    I just wanted to mention that the set_propagated_clock statements can also be important if you're not using Restore Design to bring your data up in Encounter. Most of the time, we read in verilog, def, and SDC (Import Design, defin, loadTimingCon) and if it's a postCTS design, we need to have the set_propagated_clock lines in the SDC file. So we always have a postCTS SDC file, even if that's the only difference. (We call the preCTS file design.ideal.sdc and the postCTS file design.prop.sdc.)
