  3. boundary scan chain clock routing
  • Subscribers 93
  • Views 14408
SINGI
SINGI over 16 years ago
 Dear all
 I could not get any information from various sources so thought abt putting it here, the clock routing for the bounday scan cells is normally implemented through the core digital logic which normally takes awy the routing available for other core.
Now my question, is there a tool or a procedure so  the clock routing of these scan cells are implemented in a different procedure. This way teh clock routing is not through the core digital logic but externally.
Any one who had worked on this or if they ever had a prob for this. Please share ur experience. I would like to hear all the solutions if any.
BR
SING
  • BobD
    BobD over 16 years ago
    Hi SING,
    I've not heard of a technique like this, but I'm a little unclear on how this would work.  When I think of clock routing, it usually involves the addition of buffers and wires and if you're going to do this external to the core digital logic it might help to explain where the buffers would be placed (ie, at the top level in a hierarchical design? outside the core area within a block-based design?).
    If you have information on the building blocks you would need to successfully implement this approach we may be able to help if you describe them in a little more detail.
    Bob
  • sobaesq
    sobaesq over 16 years ago
    Is your scenario where the "clock" buffer is being placed in the middle of the design (floorplan) and fanning out to the respective IO boundary scan cells/modules?   Are you using Cadence RC-DFT to insert boundary scan?  Is it only the clock signal causing you problems?
  • SINGI
    Hi
    we are using cadence RC-DFT to insert boundary scan and your correct that the clock buffer is being placed in the middle of the design and fanning out to repective IO's. This way we are using a lot of floorplan for buffers in order to meet the timings. But since all the boundary cells get input signals from out side the chip and timing is not critical,
    Do u have any suggestions or solutions to avoid this ?
     SING
