  3. LVS Fails, after P&R extra pins in layout
  • Subscribers 94
  • Views 5460
PatriciaG
PatriciaG over 12 years ago
Hello all
When runing LVS with Calibre, it fails because the layout has more pins than the schematic. Digging into it, it turned out that when streaming in the gds file generated by encounter I got labels in the internal nets. If I remove those labels, then the issue is solved.
I wonder what should I setup to avoid those labels in the internal nets? I have been stearing at the streamout.map file, the cds2gds.map and the technology file, but can't find anything that ring any bell.
Finally, we used to work with IC51 and now we are working in IC61. Does that make any difference?
Thanks!
Patricia
  • Kari
    Kari over 12 years ago
    can you post your encounter stream map?
  • PatriciaG
    This is the stream map file
    M1 NET 15 0
    M1 SPNET 15 0
    M1 VIA 15 0
    M1 PIN 15 0
    M1 LEFPIN 15 0
    M1 FILL 15 0
    M1 FILLOPC 15 0
    M1 LEFOBS 15 0
    M1 VIAFILL 15 0
    M1 VIAFILLOPC 15 0
    NAME M1/NET 15 20
    NAME M1/SPNET 15 20
    NAME M1/PIN 15 20
    NAME M1/LEFPIN 15 20
    COMP ALL 212 0
    DIEAREA ALL 212 0
  • Kari
    The only NAME lines I typically use are the PIN ones. Comment out the other NAME lines (NET, SPNET, LEFPIN, etc.) and see if that helps. If it does, you can add them back one at a time (if needed at all) and figure out which one is causing trouble.
  • PatriciaG
    Hello Kari
    Thanks a lot for the help. I did as suggested and found that I only need PIN which gives the input and output ports and SPNET that gives power and ground. I wonder what do we use  LEFPIN for? Is that technology dependant ?
    Thanks again
    Patricia
  • Kari
    LEFPIN only applies if you are streaming out with the -outputMacros switch, which you may or may not ever need to use.
