  3. RTL compiler technology transformation
  • Subscribers 94
  • Views 17289
kenambo
kenambo over 10 years ago
Hi all,
I am converting an already synthesized netlist to another technology using RTL compiler.. while doing this the generic netlist coud not generate a scan latch. It just reflects the same name in the generic netlist.
For scan flops we can unmap scan flops using,     set_attribute unmap_scan_flops true  . but for latches it doesn't apply...
so please share anything that makes this possilble.
Tanks
  • grasshopper
    grasshopper over 10 years ago
    Hi kenambo,
    Hard to answer without more information.
    I think what you need to understand is how the'latches' got in there in the first place. unmap_scan_flops should handle any cells with a scan equivalent irrespective of LSSD, FF, master-slave, etc.
    If the cell was hand instantiated, it is possible the tool does not know how or simply is not possible to represent in RTL. For example, a memory cannot be unmapped since most tools cannot infer a memory from ANY RTL.
    I am also puzzed since you indicate your design has scan latches and scan flops. This seems strange since normally you would follow a single scan methodology. Lastly, not sure what you mean by scan latches. Are these LSSD latches, master/slave latches. Latches normally do not get scan replaced hence the confusion.
    You can provide the library description of the latch and its scan equivalent and we can see if, at least, the library, has all correct construct for the tool to go from test_cell to non test and viceversa
    regards,
    gh-
  • kenambo
    Hi grasshopper
     Thanks for the reply...          Actually I am assuming it as a latch. But I dont know the exact description of that cell. I dont have the document for that.
    The cell name is "TLATNTSCAX2" It is a gpdk45nm library and it has fur pins CK(input), E(input), SE(Input), ECK(Output).
            Have you got enough info from my reply, if not please let me know.
    Thanks.
  • grasshopper
    This is not a traditional latch but an integrated clock gating cell. Such cells cannot be inferred from HDL. Therefore they cannot be unmapped to generic . These cells can be mapped using the change_link command and finding the equivalent cell on the new target library. This is no different than what you would have to do with a memory or a PLL
    gh-
  • kenambo
    Hi gh..
             Yeah I found the same while reading RTL compiler documents. And what if my new library doesn't have the integrated clock gating cell. How can I map this?
    And another one thing is.. The clock gating cell is inserted after the generic netlist has been created while we are using RTL netlist right? So why can't this clock_gating cell be unmapped?
    Anyway I will try as you said..
    Thanks.
  • grasshopper
    CGICs cannot be inferred from HDL hence cannot be 'uninferred'. You can indeed do 'clock_gating remove' and then rely on them being added again but I believe change_link is a better approach. Note change_link can relink to a module/subdesign so if your library does not have one, you would have to create a module/subdesign for it using latches/or/etc.
    gh-
