  3. clock tree synthesis
  • Subscribers 94
  • Views 16698
oAwad
oAwad over 9 years ago
Hello all,
When designing the clock tree for a design in SoC Encounter, can I specify certain clock delays for certain gates ? (for example I need the clock of gate x to rise after 0.2ns from the I/O clock pin rise). Is it possible to do this in the clock tree specification file ?
  • Kari
    Kari over 9 years ago
    you don't say if you're using CCOpt or the the old CTS. Either way, you can start out by telling the tool to balance these, but create a "macro delay" of the one that you want to be skewed out a bit.
  • oAwad
    I'm using the old CTS. What I found in the manual related to the "Macro delay" is this command:
    Macromodel pin lefPinName maxRiseDelay minRiseDelay maxFallDelay minFallDelay inputCap
    please confirm if this is what you mean. I need a delay of 0.2 ns in a special net so here is what I do:
    I create a scheduling file and add the following command to it (I'm not sure I'm setting the values correctly. Should I set the fall delays equal to the rise delays ?.....I need the whole clock to be delayed with ~0.2 ns)
    Macromodel clk_i__L5_N837 CK 0.3n 0.2n 0 0 0.9497f
    and then I set the scheduling file in the configuration file of the tool.
    and I add these two commands to my script file:
    setOptMode -usefulSkew true
    optDesign -preCTS
    Is what I'm doing correct ?
  • Kari
    Kari over 8 years ago in reply to oAwad
    Here's a sample command from an old script:
    MacroModel pin macro1/clk 300ps 300ps 300ps 300p 35fF
    I wouldn't put 0 for the fall delays. Use the same numbers as the rise.
