  2. Functional Verification
  3. How to probe a signal in verilog and VHDL.
  • Subscribers 67
  • Views 23370
stanleyao
stanleyao over 17 years ago
Hi all,
I encounter a problems.
My design hierarchy is
TOP(VHDL) - MODULE_VHD
                      |-MODULE_VERILOG
I try to probe signal of MODULE_VHD in the MODLE_VERILOG, but the signal path doesn't work.
I use the following description to assign SIG to PROBE_SIG.
initial $nc_mirror("PROBE_SIG",":TOP:MODULE_VHD:SIG","");
But it shows the message, ncsim: *E,PNOOBJ: Path element could not be found: TOP.
How to solve problem? Thanks.:)
  • Mickey
    Mickey over 17 years ago
    Sounds like you have defined the items correctly.  Do you have a simple example?  If so please send it to me (jrodrig@cadence.com).
    As another option you can try to place the ncmirror code in the vhdl block.  To do that add the following to the vhdl:
    library ncutils;
    use ncutils.ncutilities.all;
    then include the nc_mirror line in a process block (and don't include the $ sign):
    process
    begin
      nc_mirror (":path:to:verilog:item", ":path:to:vhdl:item", "");
    end process;
    Best regards,
    Mickey
  • stanleyao
    Hi Mickey,
     Thanks.
    I wrote a simple sample as below.
    entity TOP is
    end entity TOP;
    architecture Beh of TOP is
      component MODULE_VHDL is
      end component MODULE_VHDL;
      component MODULE_VERILOG is
      end component MODULE_VERILOG;
    end architecture Beh
    in the MODULE_VERILOG.
    module MODULE_VERILOG();
      reg probe_sig;
      initial $nc_mirror("prob_sig",":TOP:MODULE_VHDL:sig","");
    endmodule
    but it will show the message "ncsim: *E,PNOOBJ: Path element could not be found: TOP."
    I want to probe the signal in the MODULE_VHDL, but it looks like only signal below the hierarchy of MODULE_VERILOG could be probed.
    Is it correct?
    BR,
    Stanley
  • Mickey
    Hi Stanleyao,
    Don't include TOP in the VHDL path.  in VHDL the ":" indicates the top and then everything else is relative to that instance.  So the path for the vhdl item is ":<instance of MODULE_VHDL>:sig"
     For example:
    test.vhd
    library ieee;
    use ieee.std_logic_1164.all;
    entity test is
    end test;
    architecture vhdl of test is
    component dff
           port (d: in std_logic;
                 clk: in std_logic;
                 q: out std_logic);
    end component;
    component nc_mirror_example
    end component;
    signal clk: std_logic := '0';
    signal d: std_logic;
    signal q: std_logic;
    begin
     clk <= not clk after 20 ns;
     process
     begin
      wait for 3 ns;
      d <= '0';
      wait for 5 ns;
      d <= '1';
      wait for 13 ns;
      d <= '0';
     end process;
     inst:dff port map (d, clk, q);
     ncmirror_test_inst:nc_mirror_example;
    end vhdl;
    dff.vhd
    library ieee;
    entity dff is
     port ( d, clk: in std_logic;
      q: out std_logic);
    end dff;
    architecture behave of dff is
    begin
       process (clk)
       begin
          if (clk = '1' and clk'event) then
             q <= d;
          end if;
       end process;
    end behave;
    nc_mirror_example.v
    module nc_mirror_example;
    reg probe_sig;
    initial
      $nc_mirror ("probe_sig", ":inst:q", "");
    endmodule
    Let me know if that helps.
    Best regards,
    Mickey
  • stanleyao
    Hi Mickey,
    It works!
    I mistake the meaning of ":" in VHDL.
    Thanks a lot!! :)
    Best Regards,
    Stanley
