  2. Functional Verification
  3. Verilog Monitor to Check 'X' state of a Clock from the DUT...
  • Subscribers 66
  • Views 8029
RaghavNS
RaghavNS over 16 years ago
I want to find out the clock driven from the DUT doesn't have a 'X' State. I tried different ways of finding the 'X' State in the clock but every effort was without success.
always @ clock
if ( clock === 1'bX)
Flag Error
always @ clock
if (clock !== 1'b0 | clock !== 1'b1)
Flag error
while (clock === 1'bX)
Flag error
None of the above code Flagged an Error
Can anyone please provide me a solution for finding the 'X' state in a Signal/Clock?
I require the monitor in Verilog.
Raghav
  • Mickey
    Mickey over 16 years ago
    Hi Raghav,
    There is an assertion check in the IAL library that you can use to do this.  to use it do the following:
    1)  add an instance of ial_never_unknown_async to your verilog code.  It can either be in your current testbench or within a new standalone module that has OOMR references to the appropriate signals and connect reset_n, test_expr, and enable pins as applicable
    2)  add the following to your compile line to compile the assertion library, include the appropriate components, and invoke the assertion:  <IUS_install>/tools/ial/verilog/*.vlib  -<IUS_install>/tools/ial/include -assert
     an example would be as follows:
    module clock;
    reg clk;
    initial
      begin
      clk <= 1'b0;
      forever #5 clk <= !clk;
      end
    initial
      begin
       #7 clk <= 1'bx;
       #10 $finish;
      end
    ial_never_unknown_async test (.reset_n(1'b1), .test_expr(clk), .enable(1'b1));
    endmodule
    Hope that helps.
    Mickey
  • Mickey
    woops.  minor correction on the command line...  <IUS_install>/tools/ial/verilog/*.vlib  -incdir <IUS_install>/tools/ial/include -assert
