  2. Functional Verification
  3. Double back-tick in parametrized macro in SV
  • Replies 7
  • Subscribers 68
  • Views 24963
sevent
sevent over 15 years ago
The following code does not compile in ncverilog v9.2, I think because of the double back-tick, yet it is an example directly out of the SystemVerilog 1800-2005 spec:
 `define msg(name) name``_suffix
module macro_test;
  initial
  begin
    $display(`msg(foo));
  end
endmodule
$ncverilog macro_test.v
ncverilog: 09.20-p007: (c) Copyright 1995-2009 Cadence Design Systems, Inc.
file: macro_test.v
ncvlog: *E,EXPCPD (macro_test.v,7|21): expecting a valid compiler directive [16(IEEE)].
(`define macro: msg [macro_test.v line 1], file: macro_test.v line 7)
ncvlog: *E,NOTDIR (macro_test.v,7|21): `_suffix: not a recognized directive or macro [2.7.3][16.3.1][16(IEEE)].
The `` is supposed to delimits lexical tokens without introducing white space, allowing identifiers to be constructed from arguments.
Is this a bug with ncverilog?
  • TAM1
    TAM1 over 15 years ago
    You need to tell the compiler that this is a SystemVerilog file. You can do that by giving the "-sv" command line switch. Or you can change the filename to macro_test.sv.
  • StephenH
    StephenH over 15 years ago
    You need to add "-sv" to the command line, or change the file extension to .sv.
    Otherwise ncverilog is treating your file as Verilog 2001, which doesn't permit the enhanced macro features.
  • sevent
    Using -sv at this point is not an option due to legacy code causing syntax errors in other areas. Using the .sv extension on a more complete example still does not work:
    top.v:
    `define PREFIX foo
    `include "macro_test.sv"
    module top;
    endmodule
    macro_test.sv:
    `define MACRO(name) \
      force `PREFIX``name = 1'b1;
    module macro_test;
      reg fooA;
      initial
      begin
        `MACRO(A)
      end
    endmodule
    $ ncverilog top.v
    file: top.v
        `MACRO(A)
    ncvlog: *E,EXPCPD (macro_test.sv,10|12): expecting a valid compiler directive [16(IEEE)].
    (`define macro: MACRO [macro_test.sv line 1], `include file: macro_test.sv line 10, file: top.v line 2)
        `MACRO(A)
    ncvlog: *E,NOTDIR (macro_test.sv,10|12): `A: not a recognized directive or macro [2.7.3][16.3.1][16(IEEE)].
  • StephenH
    Using a `include from a Verilog file means the included file is also treated as Verilog, not SV.
    There is an option to turn off specific keywords in SV if you have a clash with some of your code. Have a look at the LRM for begin_keywords and end_keywords, though I suspect this isn't as flexible as you'd need.
  • jadec
    jadec over 15 years ago
    You can use -svpp to get the SystemVerilog preprocessor for your Verilog files without the code itself being considered as SV.
  • cubicle82
    cubicle82 over 15 years ago
    I'd recommend the keywords approach suggested by StephenH.
    ...but if it's at all possible, I would edit the source-files to make them compatible with Systemverilog syntax.
    A while ago, I tried to simulate a group of design-files that contained a mixture of legacy Verilog (*.v) and Systemverilog (*.sv) files. That was bad idea -- in the (SV) toplevel file, I implemented a monitor/snooper that read an 2D unpacked reg-array from the Verilog RTL by a hierarchical reference.  This caused all kinds of weird problems until I bit the bullet and hand-edited all the *.v files to be SV compatible, and read all of the files as Systemverilog.
     (For the record, I think I tried to pass the unpacked-array as an input argument to a function.  IUS62 didn't like it.)
  • jadec
    IUS 10.2 has much improved SV support. it is common to mix SV and Verilog in a simulation.
