  2. Functional Verification
  3. Configurable IO pins in SystemVerilog
  • Subscribers 67
  • Views 16705
verifs
verifs over 15 years ago
I am modelling a bfm for an IP using SystemVerilog. The model is completely class-based(OOPS) The "interface"  module has the pins of the BFM. I need one of the pins to be configurable as input or output, depending on the mode which is configured by the Host of the BFM.
I made it of type "wire" to declare it as "inout" in the "modport" of the "interface" file. But i can't use procedural assignment - this is the error i get -  "A net is not a legal lvalue in this context "
 Can anyone help me with this?
Thank you.
  • StephenH
    StephenH over 15 years ago
    How about something like:
    interface i (
      inout bd
    reg is_output;
    reg bdreg;
    assign bd = (is_output)?bdreg:1'bz;
    endinterface
    You BFM must then control is_output to set the direction. You'd read the bd pin but would write the bdreg pin.
  • verifs
    Hi Stephen,
     Thank you so much for the quick reply :)
    Your solution looks great :) I think that's exactly what I needed :) I had implemented something similar in concept, but in the classes of my driver's but never thought or knew that I could have assign statements in the Interface module itself, that makes it so much easier and the code cleaner.
    I'll try it now and will let you know how it worked.
    Thanks again.
