  2. Functional Verification
  3. use generated clock to sample the logic value driven by...
  • Subscribers 67
  • Views 15876
use generated clock to sample the logic value driven by main clock.
phoenixson
phoenixson over 14 years ago
HI, all
Now I encountered one problem when I do RTL simulation. there is one main clock named 'main_clk"  in the design, and another clock named 'clk_div2' which is generated from 'main_clk', it is divided by two, I want to use 'clk_div2' to sample the logic signal driven by 'main_clk', but I found I can not get the correct value, it seems that 'clk_div2'  sampled the next cycle value, not the current one.  what causes that ?  but after synthesizing and building clock tree, the problem disappeared, why?
  • Shalom B
    Shalom B over 14 years ago
    Is the divided clock generated with a nonblocking assignment? It should be a blocking assignment.
    Shalom
  • TAM1
    TAM1 over 14 years ago
    Do you have access to information on support.cadence.com? If so, there is an App-Note that explains why you should use a blocking vs. a non-blocking assignment in your clock tree. There are some other race condition issues that you can look for too.
     Race Conditions
