  2. Functional Verification
  3. Code coverage for sv verification envrionment
  • Subscribers 66
  • Views 3247
Jeff000
Jeff000 over 8 years ago
I referred to the link below but it seems it is much a historical solution. Now I am trying on IES 15.023. So is it possible to generate code coverage for sv verification environment with irun?
Thanks.
https://community.cadence.com/cadence_technology_forums/f/functional-verification/9140/generating-code-coverage-for-sv-verification-environment
  • StephenH
    StephenH over 8 years ago
    Yes, the answer remains the same: if you have a module-based testbench you can use "-coverage all" to enable all types of coverage and it will include the testbench modules. If you want coverage of a class-based testbench, you'll need to use the "-covfile" switch and pass some specific options, please refer to the "select_coverage" CCF command in this documentation page:  Coverage Control File options
  • tpylant
    tpylant over 8 years ago
    You can enable with CCF command:
      select_coverage –b –class
    Options are available to selectively enable coverage inside certain classes.
    • To De-select UVM package
                deselect_coverage   -b -class -module uvm_pkg
    • To deselect `UVM macros one could add to CCF
                deselect_macro        -class -name UVM*  uvm*
    The would help to reduce unwanted coverage due to standardized macros and standardized library functions.
