  2. Functional Verification
  3. SV transaction sequence dependency constraint?
  • Subscribers 66
  • Views 17540
archive over 19 years ago
Hi all, Is there any good methods to write SystemVerilog transaction sequence dependency constraint? For example, in below SV code, I want to always generate IDLE transaction after WRITE (i.e. WRITE after WRITE or READ after WRITE is illegal). //--- SV code start--- //define transactions typedef enum { WRITE=1,READ=2,IDLE=4} cmd_t; class Packet; ... rand cmd_t cmd; ... endclass Packet p; initial repert(20) begin p = new(); p.randomize(); end //--- SV code end--- Best regards, Davy
Originally posted in cdnusers.org by davyzhu
    Posted By davyzhu on 1/15/2007 12:08 AM
    Hi Davy,
    Since you're looking just one step into the past, you could simply maintain a variable with the previous transaction type, use it in a constraint, and update its value after generating each new transaction. For example:
       cmd_t prev_cmd = WRITE;
       Packet p = new;
       initial
          repeat (20) begin
              // apply constraint
              assert( p.randomize()  with {if (prev_cmd ==WRITE)  cmd==IDLE } ) else $fatal;
              // do something with p here
              // update prev value for the next iteration
              prev_cmd = p.cmd;
          end
    Now, if you want to generate more interesting sequences of transactions with a certain structure to them, you should create a new class - a sequence, which generates a stream of transactions based on some "control knobs" you set in the class instance. You can then have multiple (inherited) subtypes of that sequence class, each generating a different kind of sequence, with different knobs.
       Zeev.
    Originally posted in cdnusers.org by zeevk
    Davy,
    In cases like this, I've been using the "pre_randomize" function as follows...
    class Packet;
    rand cmd_t cmd;
    cmt_t last_cmd = IDLE;
    constraint c1 {last_cmd == WRITE -> cmd == IDLE;}
    function void pre_randomize();
    last_cmd = cmd;
    endfunction
    endclass
    Packet p;
    initial
    repeat(20) begin
    p = new();
    p.randomize();
    If someone knows a better way to do this, I'd like to hear about it.
    David Walker
    Originally posted in cdnusers.org by dbwalker0min
    Hi Zeev and David,
    Thanks a lot for the good ideas! I have tried David's program and all OK.
    And there is an small errata for above program.
    1. Assume only one instance of the class at one time
    change "cmt_t last_cmd = IDLE;" to "static cmt_t last_cmd = IDLE;"
    2. Change "function void pre_randomize(); " to "function void
    post_randomize(); "
    Best regards,
    Davy
    Hi Davy,
    One of the most powerful aspects of system verilog generation is the randsequence construct. It is a very powerful feature and is very useful in generation of sequences. It is also very scalable. I will post an example later today on how to use it.
    Nitin
    Originally posted in cdnusers.org by nitin_sharma
    Posted By davyzhu on 1/16/2007 5:15 AM
    Hi Zeev and David,
    post_randomize(); "
    Best regards,
    Davy
    Hi Davy,
    Making the last_cmd field statis is dangerous - it will not work if you have several such generator threads running simultaneously, as all the packet class instances share the static last_cmd value.
        Zeev.
