  2. Functional Verification
  3. vhdl & system verilog
  • Replies 10
  • Subscribers 66
  • Views 11915
archive over 19 years ago
   Hi All,
I have a very basic qn - jus picking up system. verilog -> if the testbench is in system verilog
and the top level is in vhdl - will both the modules be able to talk to each other?
Many Thanks in advance,
indeb
Originally posted in cdnusers.org by indeb
    Hi Indeb,
    Yes, this should work - though not defined by LRM per-se, many tools support this Mixed mode sim nicely. My experience with NC is few years old, even then it supported VHDL-Verilog cosim nicely. So at the worst case the following should work for you:
    SV_Testbench --> Verilog Top --> VHDL DUT
    Top Level in VHDL with say a SV Program instantiated also works in other simulators BTW.
    HTH
    Ajeetha, CVC
    www.noveldv.com
    Originally posted in cdnusers.org by ajeetha
    Hi Ajeetha
    sorry jus a couple of qns -> what do you mean by LRM, NC, mixed mode sim - mixed mode simulator? co sim?
    I am using modelsim - for simulation - but not too sure about the model building - when I buid the model - what is actually executing the code - I am on vnc server - I use modelsim to trace the signals - debbugging - but not too sure on how the
    codes are being built into a model - any insight?
    Thanks a mil!
    indeb
    Posted By indeb on 3/21/2007 8:46 PM
    Hi Ajeetha
    Thanks a mil!
    indeb
    LRM - Language Reference Manual
    NC - NCSIM (www.cadence.com)
    Do google search to learn more on these.
    Regards
    Ajeetha, CVC
    www.noveldv.com
    Hi Ajeetha -
    one more qn - is this declaration in sv correct?
    parameter [3:1] top_one3 = 3'b1;
    I need bits 1-3 to be high -
    Thanks in advance!
    Try = {3 {1'b1}} or 3'b111 or 3'd7
    Originally posted in cdnusers.org by bryan
    sorry I meant
    parameter [3:1] top_one3 =3'b1;
    is this okay?
    indeb
    Just to repeat what Bryan said... In SystemVerilog, if you don't specify enough bits in a constant, the leftmost bits will be set of zero. So 3'b1 will be the same as 3'b001. So you need to set all three bits high explicitly. 3'b111 or {3{1'b1}}.
    If you are just starting with the language, I'd strongly recommend that you get an introductory Verilog book. It'll pay off.
    Originally posted in cdnusers.org by TAM
    hi all:)
    thanks - but my post seems to always mess up - what i meant was i need bits 1-3 to be high and bit 0 to be low -
    so i think parameter [3:1 ]top_one3 =3'b1 .........would mean bits 1-3 high and bit 0 low?
    if the numbers in the square brackets still appear as A and 1 - i meant, three : one
    thanks
    indeb
    Try 3:0 = 4'b1110 or 4'hE or 4'd14
    Bottom line is this is basic Verilog. So getting a book a previously suggested would be a good idea. The qualifiers are working like you think. Please review the examples and you'll see important differences between what you keep typing and what other keep suggesting.
    yes i agree - i deserve that - i was under really tight schdule and kinda forgot some things - and when i did come back and look at my posts - seems like ramblings n wish could remove them - but i dont seem to be able to edit/remove once i have posted)n before someone posts a reply)-> currently using HDL Programmin fundamentals VHDL & verilog by Nazeih M Botros
    thanks
    indeb
