  2. Functional Verification
  3. connecting interfaces to old fashion DUTs
  • Subscribers 66
  • Views 18863
archive over 18 years ago
While it looks clean (or so) how to connect two module exposing interfaces, My basic question is how to connect a system verilog interface to a old fashion verilog DUT
I have an issue connecting an interface to a DUTwhich is an old fashion verilog module (Verilog 1996), i.e. with traditional port declaration
The interface looks like this
interface xram_if
  (output CLK, nRST);
timeunit 1ns;
timeprecision 1ps;
  logic [7:0] AD;
  logic ALE;
  logic nWR;
  logic nRD;
  modport master (
    output nWR,
    output nRD,
    output ALE,
    inout AD,
    import write,
    import read
  modport slave (
    input nWR,
    input nRD,
    input ALE,
    inout AD
  task init ();
   begin
    ALE = 0;
    nRD = 1;
    nWR = 1;
    AD = `DATAW'bz;
    nrst    = 1'b1;
  endtask // init
  task write (
    input t_xram_addr addr,
    input t_xram_data data
  begin
  end
  endtask // write
  task read (
    output t_xram_data data
  begin
  end
 endtask
I want to instantiate it in a test bench, e.g.
  xram_if xramif (
    .CLK(MCLK),
    .nRST(nRST)
and I need a master interface to drive my DUT (so there are modports
above)
My DUT does not support interfaces (it is Verilog 2001)
How do I specifiy
- which interface flavor (master or slave)
How doi I connect my interface to the DUT?
The following does not work ...
I think I am missing sopme big points here ...
  vdt_top i_vdt_top(
    .access_if_ale_i               (xramif.master.ALE),
    .access_if_nwr_i               (xramif.master.nWR),
    .access_if_nrd_i               (xramif.master.nRD),
    .access_if_ad_0                (xramif.master.AD[0]),
    .access_if_ad_1                (xramif.master.AD[1]),
    .access_if_ad_2                (xramif.master.AD[2]),
    .access_if_ad_3                (xramif.master.AD[3]),
    .access_if_ad_4                (xramif.master.AD[4]),
    .access_if_ad_5                (xramif.master.AD[5]),
    .access_if_ad_6                (xramif.master.AD[6]),
    .access_if_ad_7                (xramif.master.AD[7]),
I feel I am missing some big points here ...
thanks to whoever will help on this
Originally posted in cdnusers.org by marco.stanzani
    My first question is "do you really need modports?" If you are not sure, then you might be able to get by without them and your problem is solved. If you absolutely must have them, then I see the only solution is to create a wrapper for your dut that can take an interface with modport. module dut_wrapper(interface mif, sif); vdt_! top i_vdt_top( ... .access_if_ale_i (mif.ALE), .access_if_nwr_i (mif.nWR), .access_if_nrd_i (mif.nRD), ... ); endmodule module top; xram_if xramif_m (.CLK(MCLK), .nRST(nRST)); xram_if xramif_s (.CLK(MCLK), .nRST(nRST)); dut_wrapper dut (xramif_m.master, xramif_s.slave); endmodule Tim
    Originally posted in cdnusers.org by tpylant
    Hello tplyant
    thanks for looking into my issue, first.
    Then, assuming modport is not there any longer, i.e
    interface xram_if
        output CLK,
        output nRST
    timeunit 1ns;
    timeprecision 1ps;
      logic [`DATAW-1:0] AD;
      logic ALE;
      logic nWR;
      logic nRD;
      task write (
      begin
       nWR=1;
       nRD=1;
       AD = `DATAW'bz;
       ALE=1;
       #(tLHLL-tAVLL);
       AD = addr[`DATAW-1:0];
       #(tAVLL);  // Addrss valid to ALE low
       ALE=0;
       #(tLLAX);
       AD =`DATAW'bz;
       #(tLLWL-tLLAX-tQVWX);
     etc
    I tried to connect interface signals, which I did not declared as ports, just 'logic' in the inetrface
        .access_if_ale_i               (xramif.ALE),
        .access_if_nwr_i               (xramif.nWR),
        .access_if_nrd_i               (xramif.nRD),
        .access_if_ad_0                (xramif.AD[0]),            <<-- inout
        .access_if_ad_1                (xramif.AD[1]),
    ALE, nWR,nRD seems OK, but I havve an issu with bidirs
    ncelab: *E,CUVMIO (../hdl/tb.v,213|44): port connections to inout ports must be collapsible, that is, they must be nets.
    Defininmg AD ad tri instead of logic does not help ...
    regards
    First let me make a correction to my code. There should only be one instance of the interface. module top; xram_if xramif (.CLK(MCLK), .nRST(nRST)); dut_wrapper dut (xramif.master, xramif.slave); endmodule Now to address your last issue. Since you are not using modports to separate AD to input or output, I assume you are having to connnect to an inout. This means that you will have to use standard coding methods to connect to inout. interface xram_if(...); ... wire [`DATAW-1:0] AD logic [`DATAW-1:0] data_out; assign AD = !nWR ? data_out : 'z; ... task write(...); ... data_out = addr[`DATAW-1:0]; ... endtask ... endinterface I attached a testcase that demonstrates this. Tim
    test_if.tar.gz
