  2. Functional Verification
  3. Clock Generation using sys.any
  • Subscribers 66
  • Views 16717
archive over 18 years ago
Hi Everybody,
I am stuck in a doubt that seems to be a really easy one for expert users, but that is my first VE .
Problem: My DUT needs a clock which I don't want to create in HDL, I would like to generate it in Specman.
My First Approach: I was reading the Verification Advisor which recommends in this case the use of sys.any. But in the same Verification Advisor is written:
sys.any is a pre-defined event that has two main functions:
* Without a simulator
sys.any acts like a clock that ticks every cycle (the highest possible frequency) and can be used to sample other clocks, events, and TCMs.
* With a simulator
sys.any is emitted on every callback of the simulator (thus being unpredictable) and should not be used as a clock unless there is no other option.
Questions:
1 - As long as I want to use this generated clock to test the DUT how would I do? The Advisor says that sys.any is unpredictable when acting with simulator..
2 - How would I know what is the frequency which I am generating the clock? How would I determine the highest possible frequency?
3 - Is there any other way for doing that or should I give up and use verilog?
Any help would be really appreciated!
Filipe Tabarani
Ps: I am currently verifying a I2C implementation, if someone has any document, eVC or tips which could helps. I would be really thanks.
Originally posted in cdnusers.org by tabarani
    It is ideal to model clock and reset in the HDL because of performance reasons. Being said that you can generate clock in e code by simple using a TCM that runs off sys.any and has wait delay statement. Here is an example:
    Script started on Thu 13 Mar 2008 05:35:46 PM CDT id: cannot find name for group ID 1001 ca[jigar@lnx-jigar clock_gen]$ cat clock_gen.e <' unit clock_driver { clk: inout simple_port of bit is instance; keep bind (clk, external); keep soft clk.hdl_path() == "clock"; gen_clock() @sys.any is { clk$ = 0; while TRUE { -- Create clock with 200 ns period, 50% duty cycle wait delay(100 ns); clk$ = ~clk$; }; }; run() is also { start gen_clock(); }; }; extend sys { clock_driver_i: clock_driver is instance; keep clock_driver_i.hdl_path() == "~/top"; }; '> [jigar@lnx-jigar clock_gen]$ cat top.v module top(); reg clock; initial begin @(posedge clock); $display("Got postive edge of clock at time %0d", $time); @(negedge clock); $display("Got negative edge of clock at time %0d", $time); $finish; end endmodule [jigar@lnx-jigar clock_gen]$ cat [K[K[Kirun -nosncomp co[Klock_gen.e top.v irun: 06.20-s004: (c) Copyright 1995-2008 Cadence Design Systems, Inc. Loading snapshot worklib.top:v .................... Done Initializing Incisive Enterprise Simulator (06.20) - Linked on Sun Jan 13 16:31:20 2008 Protected by U.S. Patents 6,920,583; 6,918,076; 6,907,599; 6,687,662; 6,684,359; 6,675,138; 6,530,054; 6,519,727; 6,502,232; 6,499,132; 6,487,704; 6,347,388; 6,219,809; 6,182,258; 6,141,630; Other Patents Pending. exit Checking license ... OK Doing setup ... Generating the test using seed 1... Starting the test ... Running the test ... Running should now be initiated from the simulator side ncsim> source /localhome/jigar/softwares/ies62/IUS62/tools/inca/files/ncsimrc ncsim> run Got postive edge of clock at time 100 Got negative edge of clock at time 200 nc_specman is doing end-of-test operations Checking the test ... Checking is complete - 0 DUT errors, 0 DUT warnings. End-of-test operations are completed Simulation complete via $finish(1) at time 200 NS + 1 ./top.v:9 $finish; ncsim> exit Script done on Thu 13 Mar 2008 05:36:13 PM CDT
    Originally posted in cdnusers.org by pjigar
    Sorry for the garbled reply earlier.
    unit clock_driver {
         clk$ = 0;
         while TRUE {
           wait delay(100 ns);
           clk$ = ~clk$;
      run() is also {
        start gen_clock();
    extend sys {
    module top();
      reg clock;
      initial begin
        @(posedge clock);
        @(negedge clock);
        $finish;
      end
    endmodule
    16:31:20 2008
    exit
    Doing setup ...
    ncsim> run
    ./top.v:9     $finish;
    ncsim> exit
    Thx !! This was really helpfull! So I will do that in HDL, but it´s good to know how to do it in Specman.
