  2. Hardware/Software Co-Development, Verification…
  3. How will I do a HAL Hdl analysis on vhdl design?
  • Replies 7
  • Subscribers 50
  • Views 21524
sonam20
sonam20 over 14 years ago
I want to do a HAL analysis on VHDL design.What are the procedure and steps for that?/
Please tell me
thanks,
Shivani
  • StephenH
    StephenH over 14 years ago
    Hi Shivani.
    If you compile your design with "irun" already then you can just add the "-hal" switch, then use the "ncbrowse" tool to review the lint messages via a GUI.
    Alternatively if you use ncvhdl/ncelab/ncsim, then after elaboration you can invoke "hal" and pass the snapshot name on the command line to HAL.
  • sonam20
    apply command "nclaunch"
    select a design
    select all vhd files in selcted design and press ncvhdl option .
    After this it give various errors .. How to resolve that?
    How to elaborate particlar design?
    thanks
    Shivani
  • sonam20
     How to get sanpshot of elaborated design.??
  • StephenH
    Shivani,
    Without seeing your compilation log there is no way to know what those VHDL errors are, nor can we guide you to resolve those unknown errors. I would recommend talking to one of your colleagues to get the required compilation order for the files, as well as any specific switches like VHDL-93 options etc.
    Alternatvely you could post the log file here, or go to http://support.cadence.com/ and file a service request asking for help to run HAL.
    Steve.
  • sonam20
    HI,
    I found these type of error after compilation. Please tell me how to resolve them.
     ncvhdl_p: *E,LIBNOM (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,35|18): logical library name must be mapped to design library [11.2].
    USE DESIGN.BB_PKG.All;
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,38|9): identifier (DESIGN) is not declared [10.3].
    USE DESIGN.WB_INTERNAL_PKG.ALL;
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,39|9): identifier (DESIGN) is not declared [10.3].
    USE DESIGN.COMMON_PKG.ALL;
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,40|9): identifier (DESIGN) is not declared [10.3].
        P_SLAVE_BASE_ADDR : slave_addr_a_t(0 TO P_NUM_SLAVES-1)      := (((x"0000"),(x"0280"),(x"0000")),  --! Specifies base address of each slaves
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,48|37): identifier (SLAVE_ADDR_A_T) is not declared [10.3].
        P_SLAVE_ADDR_SIZE : slave_addr_a_t(0 TO P_NUM_SLAVES-1)      := (((x"007f"),(x"027f"),(x"0000")),     --! Specifies the address size of each slave
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,52|37): identifier (SLAVE_ADDR_A_T) is not declared [10.3].
        P_SLAVE_ADDR_CH   : slave_addr_ch_a_t(0 TO P_NUM_SLAVES-1)   := (('1','1','0'),     --! Specifies the active address part of each slave
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,56|40): identifier (SLAVE_ADDR_CH_A_T) is not declared [10.3].
        P_SHARE_PRIO      : int_vector(0 TO P_NUM_MASTERS-1)         := (1,2,3,4,5)         --! Priority of master
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,60|33): identifier (INT_VECTOR) is not declared [10.3].
        wbm_i       : OUT wbm_i_a_type(0 TO P_NUM_MASTERS-1);  --! Wishbone master input interface array
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,71|33): identifier (WBM_I_A_TYPE) is not declared [10.3].
        wbm_o       : IN  wbm_o_a_type(0 TO P_NUM_MASTERS-1);  --! Wishbone master output interface array
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,72|33): identifier (WBM_O_A_TYPE) is not declared [10.3].
        wbs_o       : IN  wbs_o_a_type(0 TO P_NUM_SLAVES-1);   --! Wishbone slave output interface array
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,76|33): identifier (WBS_O_A_TYPE) is not declared [10.3].
        wbs_i       : OUT wbs_i_a_type(0 TO P_NUM_SLAVES-1)    --! Wishbone slave input interface array
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,77|33): identifier (WBS_I_A_TYPE) is not declared [10.3].
    ARCHITECTURE rtl OF intercon IS
    ncvhdl_p: *E,ENNOFN (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_generic.vhd,82|27): Intermediate file for entity 'INTERCON' could not be loaded, entity may require re-analysis.
    LIBRARY design;
    ncvhdl_p: *E,LIBNOM (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,39|13): logical library name must be mapped to design library [11.2].
    USE design.bb_pkg.ALL;
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,40|9): identifier (DESIGN) is not declared [10.3].
    USE design.common_pkg.ALL;
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,41|9): identifier (DESIGN) is not declared [10.3].
        dm_in         : IN dm_in_a_t(0 TO P_NUM_REG_MAP-1);   --! Number of elements = no. of register maps
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,50|31): identifier (DM_IN_A_T) is not declared [10.3].
        reg_wbs_i     : IN  wbs_i_type;
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,54|33): identifier (WBS_I_TYPE) is not declared [10.3].
        dm_out        : OUT  dm_out_t;
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,58|32): identifier (DM_OUT_T) is not declared [10.3].
        reg_wbs_o     : OUT wbs_o_type
    ncvhdl_p: *E,IDENTU (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,62|33): identifier (WBS_O_TYPE) is not declared [10.3].
    ARCHITECTURE rtl OF wb_dm_bridge IS
    ncvhdl_p: *E,ENNOFN (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,68|31): Intermediate file for entity 'WB_DM_BRIDGE' could not be loaded, entity may require re-analysis.
      Concatenation: FOR i IN P_NUM_REG_MAP DOWNTO 1 GENERATE BEGIN
    ncvhdl_p: *E,EXPEND (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,83|58): expecting the reserved word 'END' [9.7].
    END ARCHITECTURE rtl;
    ncvhdl_p: *E,OPARCH (/projects/MC_E_E1/wrk/ssharma/shi/trunk/src/design/backbone/wb_con/wb_dm_bridge.vhd,134|15): Optional end architecture is only allowed in 93[1.2].
    ncvhdl_p: Memory Usage - 8.4M program + 4.9M data = 13.2M total
    ncvhdl: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.1s, 24.0% cpu)
  • Brodov Dmitriy
    Brodov Dmitriy over 14 years ago
    You can use cadence quick help for more explanation: nchelp ncvhdl_p LIBNOM
    ncvhdl_p/LIBNOM =
            The logical library name indicated is not mapped to a design library.
            Section [11.2] of LRM [87 & 93].  A user option file entry of the form:
                    L: directory
            must be present for each logical library name L.
  • TAM1
    TAM1 over 14 years ago
    This message, which seems to be the cause of most of the following error messages, is saying that the parser doesn't know where to look to find the compiled objects for the BB_PKG package. It doesn't know where the library called "DESIGN" was stored.
    Cadence tools use a file called "cds.lib" to map logical library names to physical disk locations. Search for "cds.lib" in the NCLaunch documentation for help in setting up that mapping file.
