  2. Logic Design
  3. cadence RTL compiler...WNS (Worse Negative slack)
  • Subscribers 63
  • Views 19001
ChInNi miSSing
ChInNi miSSing over 15 years ago
Respected all,
Am synthesizing my HDL code using cadence RTL compiler. Am getting a slack of -14586 ps my clock was 10 ns.
i need to optimize my slack to a small positive value, and my critical path is between a reg to reg (C2C).
for doing this i need to apply some constraints na, i have applied output delay, input_delay constraints, but in order to apply these constraints the critical path should be between input and output pins, so no changes have done to the slack and critical path.
please guide me something to overcome this negative slack...
Next, Is it possible to increase the size of a particular gate  to reduce the delay of that particular cell in the design during synthesis using some commands or anything ???
If, so please guide me....
waiting for u r reply
thanking you all..
  • mclarke
    mclarke over 15 years ago
      I have noticed you did not mention any clock definitions which is th typical way to constrain reg to reg paths. This can be done using either std sdc constrain syntax.  RTLC will automatically resize cells to reduce delay provided lib cells of variouse sizes are avalible in the library.
    Cheers,
      Mike
  • grasshopper
    grasshopper over 15 years ago
     As per guide, I would think the documentation and the write_template command are the best places to start
    Without a timing report of the path in question, it is pretty hard if not impossible to tell what the problem is.
    10ns cycle time is ample cycle time in most modern libraries so it sounds like you are failing to synthesize or have
    Not constrained the design properly. RC will always optimize to meet timing given your constraints.
    At a minimum you should make sure you provide the following constraints:
    + clock
    + input delays
    + output delays
    Note that even a design without flops would most likely have clocks since input and output would have a clock reference
    As per resizing cells, that can certainly be done manually but should happen automatically if properly constrained
    Gh-
  • ChInNi miSSing
    Respected mclarke ......
    I am very thankful to you for responding to me..........
    define_clock -name clk -period 10000 [find / -port clk]
    this is my clock with 10 ns period...
    i am getting a slack of -16586 ps, i need to optimize it to a small positive valu.
    How to optimize it....please give some suggestions
  • ChInNi miSSing
    Respected  Gh,
    thank you so much for u r reply
    i have defined my clock like this with a 10 ns time period
    and i am giving input and output delay of 1.5 ns to all inputs and outputs.
    then also am getting negative slack. then how to reduce the delay using RTL compiler commands
