  2. Logic Design
  3. RTL Compiler: write_sdf and clocks
  • Subscribers 63
  • Views 17281
moogyd
moogyd over 15 years ago
I am trying to run some pre-layout gate level simulations for a design. The design contains clock gating, and no clock trees.
I would like to assume an ideal clock tree, and would be happy to exclude all timing associated with the clock paths (i.e. set to 0).
Is there any way of acheiving this with the write_sdf command. i.e. Set all delays associated with clocks (or ideal_nets) to be 0?
Steven
  • mclarke
    mclarke over 15 years ago
     Hi Steven,
      In RTLCompiler th clock path are by default ideal. So unless you have added a set_clock_latency on your clock rc will assume 0. In the sdf file using 'write_sdf -interconn interconnect' will crt the net values where you can see the clock wire delay is forward annotated to the arrival pin as 0.0.
    Cheers,
      Mike
  • moogyd
    Hi Mike,
    The actual delays I was concerned about are the path delays through the integrated clock gate cells. I was hoping that these would be set to 0, but the are  not.
     Any other suggestions (other than editing the SDF file ;-) )
    Steven
  • mclarke
    Hi Steven,
       If you know or can find the specific net names then use ::dc::set_ideal_net ::dc::set_ideal_network just before you write the scf file.
    Mike
