  2. Logic Design
  3. reading synthesized design
  • Subscribers 61
  • Views 16421
archive over 20 years ago
Is it possible to read in a synthesized design in rtlcompiler for reporting purposes? I know that in synopsys there is a possibility to read in the .db file and thus not having to re synthesize an old design for reporting purposes. My synthesis takes several hours and one little ctrl z by mistake can end the whole session which can be really frustrating...
/Mike
Originally posted in cdnusers.org by mike.c
    you should be able to do the following
    after you load your libraries
    read_hdl your_last_verilog
    read_sdc your_sdc_file
    elaborate
    report timing
    li siang
    Originally posted in cdnusers.org by lisiang
    Hi Mike,
    Li Siang is right, you can easily reload any verilog netlist and write reports. The only one I've seen that doesn't work for this is reporting on power. I've seen that RC doesn't (always) identify the clock-gating correctly, especially if your original setup files set things like the default activity. Timing, Area, Gates and even DFT work fine.
    Hope this helps,
    CD
    Originally posted in cdnusers.org by crispy_duck
    I never managed to read in the .sdc file properly, instead I use my .tcl constraint files and then It works to some extend. When comparing my old report files with the new ones most of the paths are the same but some differ, is this correct or should the report files come out identical?
    /Mike
