  2. Logic Design
  3. constraining between ports and clock domain
  • Replies 19
  • Subscribers 61
  • Views 27680
archive over 19 years ago
I have a clock named "clk_design". How can I constrain all paths between input ports and this clock?
I have applied following:
define_cost_group input_to_clk_design
path_group -from /designs/*/ports_in/* -to clk_design -group input_to_clk_design -name input_to_clk_design_path
But when I apply report timing -cost_group input_to_clk_design, report tells me that no path group has been found.
Any ideas? What shall i give as -to option for path_group?
Originally posted in cdnusers.org by sporadic crash
    dc::set_input_delay should work, how do you apply it?
    Originally posted in cdnusers.org by synthman
    set_input_delay $delay -clock clk_designl $inputs
    it is called from an SDC file. I have written in the previous posting to imply that I have used an SDC style, not RC style.
    Am I missing anything here?
    In your previous email you wrote
    1. create_clock
    2. define_cost_group
    3. path_group
    You need to read the sdc between 1 and 2. not before 1 or after 3.
    Eric.
    Originally posted in cdnusers.org by evenditti
    1. create_clock is in an SDC file, called by another TCL script, using "read_sdc".
    2. and 3. are in the TCL script, after the read_sdc call.
    after external_delay, I have applied dc::set_input_delay again, RC tells me that external_delay is removed.
    Are both commands equivalent, ie. "dc::set_input_delay" and "external_delay"?
    external_delay is equivalent to both dc::set_input_delay and dc::set_output_delay. Your command sequence looks correct, not sure what the problem is without seeing all the data. If you have access to Cadence Support, send in the data.
    Hi Eric, I have read all the postings and have read your last sentence in one of your previous postings again: "...for example if you input delay use clk_design and you have a path_group -from clk_design -to clk_design you will also have your input to clk_design in that group." That means RC covers this path. I am not at my desk now, but will check it as soon as possible. Then that means when I define cost_group for a clock domain, then I do not need to define -from "external_port" to a clock domain. I am using this tool for my first time, but it is pretty similar to Xilinx constraint mechanism. However RC is more "intelligent" about assigning clock domains. I will return you when I get news things.
    You can try the following:
    include load_etc.tcl
    define_cost_group -name I2C -design $DESIGN
    path_group -from [all::all_inps] -to [all::all_seqs] -group I2C -name I2C
    foreach cg [find / -cost_group *] {
    report timing -cost_group $cg >> $RPT_NAME
    It creates path group from all inputs to registers, sampling the data from the inputs.
    The clock and input delays should be defined before.
    Originally posted in cdnusers.org by Stalker
    I think
    is an overkill in a multi-milliongate design, because RTL Compiler by default definition will try to analye "all flipflops" in the design, which costs a lot of runtime.
    IMHO, the clock domains must be grouped separately.
    I have found the reason, why I don't see that any path found for the port I have selected.
    It has to do with that I have unknowingly set a "default" input delay just before the corresponding set_input_delay, which takes the port to another clock domain.
    Therefore the second dc::set_input_delay does not take the port to another clock domain, unless the previous is removed. Therefore RTL Compiler does not find a path between the port and the clock domain I wanted, unless there is no "dc::set_input_delay" defined for the clock domain.
    Thanks folks. your messages helped me a lot. Especially Eric's email.
