  2. Logic Design
  3. sub architecture selection
  • Replies 13
  • Subscribers 61
  • Views 23940
archive over 19 years ago
In a block with deep asynchronous logic, there are some multiplier stages. I synthesized this block stand-alone and "report datapath" does not show me a multiplier architecture for it. Then I have applied following pragma:
assign some_prod[24:0] = {15'h0,some_term1[9:0]} * /* cadence sub_arch booth */ {{10{some_term2[14]}},some_term2[14:0]};
Please note the sign extension for the 2nd term.
Neither elab nor "synthesize -to_generic -effort high" shows me an information about this setting. The results with pragma above are without pragma are the same, ie. pragma does not seem to have an effect.
set_attr user_sub_arch booth [find / -design my_design]
does not work, because the attribute can be assigned only to subdesigns.
The reason why I do this experiment in a stand-alone synthesis is that the runtime of the complete system takes ca. 6 hours.
RC is v06.20-p003_1.
Can the HDL coding style affect the mechanism of inferring synthetic operators?
Originally posted in cdnusers.org by sporadic crash
    Sorry for my stupid posting again. It is crystal clearly stated in the cdsdoc in which conditions and which RTL coding enables automatic architecture inferring.
    archive over 18 years ago
    I still have an issue in this subject. RTL code pragmas for architecture selection do not seem to be working. Here is an example. Following is a multiplier kernel:
    module mult_kernel #(
    parameter WIDTH_A = 5,
    WIDTH_B = 10
    input [WIDTH_A-1:0] terma,
    input [WIDTH_B-1:0] termb,
    output [WIDTH_A*WIDTH_B-1:0] prod
    assign prod = terma * /* cadence sub_arch booth */ termb;
    endmodule
    Following block is top-level of multiplier kernel:
    module mult_prm #(
    WIDTH_B = 10
    input clk_data,
    input rst_data_n,
    input enable,
    output reg [WIDTH_A*WIDTH_B-1:0]prod
    reg [WIDTH_A-1:0] terma_int;
    reg [WIDTH_B-1:0] termb_int;
    always @(posedge clk_data)
    if (!rst_data)
    begin
    terma_int <= 0;
    termb_int <= 0;
    end
    else if (enable)
    begin
    terma_int <= terma;
    termb_int <= termb;
    wire [WIDTH_A*WIDTH_B-1:0] prod_int;
    mult_kernel #(WIDTH_A, WIDTH_B) my_mult (terma_int, termb_int, prod_int);
    if (!rst_data_n)
    prod <= 0;
    else if (enable)
    prod <= prod_int;
    endmodule
    Although I have specified the architecture selection as "booth", RTL Compiler does not even generate an informative message about that the tool recognized the attribute setting.
    The design above is very simple, as you see. I have done the things above exactly as it is stated in Datapath Optimization part of the Datapath Synthesis in Encounter RTL Compiler chapter.
    However RTL Compiler generate a non_booth architecture.
    I am using special licenses for RTL Compiler. Is this booth feature so difficult to set it up?
    Try "report datapath" after elab (need to set_attr hdl_track_filename_row_col true before elab), it will show:
    Module Instance Operator Signedness Architecture Inputs Outputs CellArea Line Col Filename
    mult_unsigned my_mult/mul_45_21 * unsigned very_fast/booth(u) 5x10 15 9089.71 45 21 mult.v
    Originally posted in cdnusers.org by synthman
    No, "report datapath" gives me a non-Booth architecture.
    I have RTL Compiler v07.10-s009_1.
    mult_unsigned my_mult/mul_11_21 * unsigned very_fast/non_booth 5x10 15 3381.38 11 21 mult_kernel.v
    Hi Sporadic Crash,
    I have never used this pragma and, to be honest, I am not much of a fan of them but this one definitely peeked my curiosity. I made some minor mods to the code you posted since there were a couple typos. Hopefully this is not the cause of my success. I ran RC v07.10-s009_1 and the following simple script
    set_attr library tutorial.lbr
    read_hdl -v2001 booth.v
    elab
    report datapath
    synth -to_mapped
    report datapath
    both report datapath displayed booth. I tried it without the pragma and it showed non-booth. Pretty cool !!!
    Though I have been brain washed :) and converted to the very_slow to very_fast approach RC uses. Makes my life easier . . .
    Here is the HDL I used which should be almost identical to the one you posted
    WIDTH_B = 10
    endmodule
    module mult_prm #(
    WIDTH_B = 10
    input clk_data,
    input rst_data_n,
    input enable,
    if (rst_data_n)
    begin
    terma_int <= 0;
    termb_int <= 0;
    end
    else if (enable)
    begin
    terma_int <= terma;
    termb_int <= termb;
    end // if (enable)
    if (!rst_data_n)
    prod <= 0;
    else if (enable)
    prod <= prod_int;
    endmodule
    happy thanksgiving,
    gh-
    Originally posted in cdnusers.org by grasshopper
    No, I still *do not* have it:
    Elaboration tells me:
    Info : An implementation was inferred. [CWD-19]
    : The implementation '/hdl_libraries/GB/components/mult_unsigned/implementations/very_fast' was inferred through the binding 'b1' for the call to synthetic operator 'MULT_UNS_OP' (pin widths: A=5 B=10 Z=15) at line 11 in the file 'booth.v'.
    Info : Sorted the set of valid implementations for synthetic operator. [CWD-36]
    : The implementations for the call to synthetic operator 'MULT_UNS_OP' (pin widths: A=5 B=10 Z=15) at line 11 in the file 'booth.v' will be considered in the following order: {'/hdl_libraries/GB/components/mult_unsigned/implementations/very_fast' (priority 1), '/hdl_libraries/GB/components/mult_unsigned/implementations/medium' (priority 1), '/hdl_libraries/GB/components/mult_unsigned/implementations/slow' (priority 1)}
    but then:
    Inferred components
    mult_unsigned_mbvp_l my_mult/mul_11_21 * unsigned slow/non_booth 5x10 15 1105.28 11 21 booth.v
    2qtv
    :) What is that now??
    1. read_hdl
    2. elaborate
    3. read_sdc
    4. synthesize -to_generic
    5. synthesize -to_mapped -no_incremental
    6. synthesize -to_mapped -incremental
    After each call of "synthesize" I generate "report datapath". NONE of them gives me a report about Booth architecture.
    Hi Grasshopper,
    the distributed approach has an incremental tech mapping as you see. I cannot tell the reason for company reasons.
    I have removed the 4th part (generic synthesis) which leads that step 5 performs full synthesis. No, there is no change in the architecture.
    I think this selection happens during elaboration time. As you see, elab report tells me the architecture will be very_fast but report datapath tells me it is not. OTOH, RTL Compiler docs tell me that Booth arch is selected automatically only if WIDTH > 13. I don't have it here.
    Grasshopper, do you have specail Cadence env var or special attrib for that?
    Re-run with your script and out-of-the-box setup
    set_attr information_level 9 /
    elab
    report data
    synth -to_gen
    report data
    synth -to_mapped -no_incr
    report data
    synth -to_mapped -incr
    report data
    and here is the output
    Cadence Encounter(R) RTL Compiler
    Version v07.10-s009_1 (32-bit), built Aug 8 2007
    Setting attribute of root '/': 'information_level' = 9
    Reading Verilog file 'booth.v'
    Elaborating top-level block 'mult_prm' from file 'booth.v'.
    Elaborating block 'mult_kernel_WIDTH_A5_WIDTH_B10' from file 'booth.v'.
    : The implementation '/hdl_libraries/GB/components/mult_unsigned/implementations/very_fast' was inferred through the binding 'b1' for the call to synthetic operator 'MULT_UNS_OP' (pin widths: A=5 B=10 Z=15) at line 10 in the file 'booth.v'.
    : The implementations for the call to synthetic operator 'MULT_UNS_OP' (pin widths: A=5 B=10 Z=15) at line 10 in the file 'booth.v' will be considered in the following order: {'/hdl_libraries/GB/components/mult_unsigned/implementations/very_fast' (priority 1), '/hdl_libraries/GB/components/mult_unsigned/implementations/medium' (priority 1), '/hdl_libraries/GB/components/mult_unsigned/implementations/slow' (priority 1)}
    Done elaborating 'mult_prm'.
    Command: report datapath
    Generated by: Encounter(R) RTL Compiler v07.10-s009_1
    Generated on: Nov 20 2007 12:32:41 PM
    Module: mult_prm
    Technology library: tutorial 1.0
    Operating conditions: typical_case (balanced_tree)
    Wireload mode: enclosed
    Inferred components
    mult_unsigned my_mult/mul_10_21 * unsigned very_fast/booth(u) 5x10 15 594.75
    Generated on: Nov 20 2007 12:32:42 PM
    Module: mult_prm
    Inferred components
    mult_unsigned my_mult/mul_10_21 * unsigned very_fast/booth(u) 5x10 15 591.75
    Generated on: Nov 20 2007 12:32:46 PM
    Module: mult_prm
    Inferred components
    mult_unsigned my_mult/mul_10_21 * unsigned slow/booth(u) 5x10 15 379.50
    Module: mult_prm
    Inferred components
    Sorry but did not do anything special I am aware of
    good luck,
    gh-
    Grasshopper,
    your technology library and constraints might be a little more relaxed than by me.
    On the other hand, does RTL Compiler generate any message about your inline pragma coded in RTL code? (cadence sub_arch booth).
    As we see in the reports above, RTL Compiler changed the sub-architecture selection from very_fast/booth to slow/booth, after the generic synthesis. That means, even if you might set the user_speed_grade, the RTL Compiler will change the sub-architecture selection during technology mapping time. In other words, if you had tighter constraints, you would probably not have been Booth architecture, either...
    In your technology/constraints it is possible. In my technology/constraints, not.
    I will relax my timing closure now and will see whether it will cheat RTL Compiler to infer fast synthetic operator as Booth multiplier...
    Grasshopper,
    i have found the reason. The reason is the script I am using is setting input_pragma_keyword attribute a value other than default setting, which does not include the string "cadence" any more. Therefore RTL Compiler does not recognize the cadence inline pragma any more.
    When I keep the attribute input_pragma_keyword in its default value, I get Booth architecture, because RTL Compiler recognizes inline pragma keyword "cadence".
    When I change the value of this attribute in such a way that its value does not include string "cadence", RTL Compiler is unable to recognize the inline pragma keyword "cadence" and thus it does not infer Booth operator.
    But I will contact Cadence to tell them that neither read_hdl nor elaborate produces any message saying that it recognized the inline pragma in the default value of the said attribute.
