  2. Logic Design
  3. CCD check fails as Encounter cannot parse a design file...
  • Subscribers 61
  • Views 8059
CCD check fails as Encounter cannot parse a design file which has a "generate" block in it
dp2402
dp2402 over 14 years ago
Hello all,
I am currently running a CONFORMAL (R) Constraint Designer v10.10 check for an IP which consists several *.v files.
In one of the .v files the "generate" statement has been used -- This is causing an error while I run my CCD script.
Error msg given by compiler:
// Parsing file ~hdl/abc.v ...
// Error: hdl_default_checks/rtl_checks/RTL13.6: Standalone generated blocks are not supported in the IEEE standard
// In line 235, file '~hdl/abc.v'
// Error: Fail to read design.
// Read design summary: Error: 1, Warning: 0, Note: 0
CCD script which reads the design file:
read design -verilog2k -define <company_tech_name>\
-root <....> \
-parameter <...> \
hdl/some_file.v \
hdl/abc.v \
hdl/some_file.v \
-lastmod -noelab
Please throw some light on the RTL13.6 error message and tell me which switch I shall use witn the "read design" command so that the error message regarding use of "generate" statement in design dosen't show up?
Hope I am clear in the explanation!
  • Shalom B
    Shalom B over 14 years ago
    A standalone generate block is one in which the generate construct contains content outside a generate-if/case/for.
     Example:
    generate
    wire x;
    endgenerate
    The 'wire x;' declaration does not appear inside a generate if/for/case.
    This is legal in Verilog-2001, but not in Verilog-2005 and SystemVerilog.
    Maybe Conformal has a switch to tell it to use the 2001 version instead of the 2005 versio.
    Or you can tell Conformal to treat this as a warning instead of an error.
    Shalom
  • dp2402
    Yes, that's what I believe too, that the "read design" must be having a switch!
    You see in my 1st post, I am already using the switch " -verilog2k  " but that dosen't solve the problem.
    I have checked the Conformal_Ref.pdf documentation for all switches belonging to the cmd "read design", but couldn't find it there.
    Also it is no use changing an Error to a Warning! Coz if my script cannot parse the design file, it is no use running the constraint.
    I am using CCD for the 1st time & have no experience!
  • croy
    croy over 14 years ago
    R&D made RTL13.6 an error in 10.1. It went back to a warning within 2 months. You could download 11.1 or do 'set rule handling RTL13.6 -warning' if continuing with 10.1.
    Chrystian
  • dp2402
    Hi Chrystian,
    Just when I thought my problem is solved, CCD now says that RTL13.6 is an unknown rule!
    But if I run the script without the 'set rule handling ....', compiler gives error:
    :(  Can't understand what's happening!
  • croy
    Please use 10.10-s280 or later.
    set rule handling hdl_default_checks/rtl_checks/RTL13.6 -severity warning
    Chrystian
  • dp2402
    Thanks a lot  Chrystian.
    Works perfectly!
