  2. Logic Design
  3. RTL Compiler: VCD Annotation and CPF
  • Subscribers 63
  • Views 17571
moogydmaxim
moogydmaxim over 13 years ago
In RTL compiler, I have successfully used the following flow
- Read Verilog Netlist
- Read VCD Annotation Data between times t0 and t1 (Chip "Active")
- Report Power for "Active"
- Reset Design
- Read VCD Annaotation Data between  times t2 and t3 (Chip "Standby")
- Report Power for "Standby"
This has worked succesfully and reported "Active" and "Standby" power is as excpected
I am now trying to improve the flow by reading the CPF file, which defines the power modes. So, now I attempting to report power for each power mode, whilst also including the VCD annotation data.
Unfortunately, this does not seem to work. As far as I can tell, the VCD annotation data is not being used in the power calculation such that the power is the same in both "Active" and "Standby".
Has anyone used this flow? Should it work?
 Steven
  • Fotios Nt
    Fotios Nt over 13 years ago
     Hi Steven,
    The solution to your problem would be one of the following.
    Solution #1: Annotate switching activities for each power mode in your cpf file. Check update_power_mode -activity_file command .
    Solution #2: Your flow should look something like this:
    read_cpf -library
    read_hdl
    elaborate
    read_cpf
    read_tcf
    synth -to_generic
    //diagnostics, reports etc here
    commit cpf
    synth -to_map
    Notice that we read tcf (or vcd or saif) AFTER read_cpf . If you try to read it before, you won't get accurate results
    Hope I helped,
    Fotis
  • moogydmaxim
    Hi Fotis,
    Thanks for the reply - I am trying your solution #2 - the only difference is that I am using a GL nelitst.
    Therefore, my flow is
    1) read_cpf (libraries)
    2) read_netlist
    3) read_cpf
    3) read_vcd -start_time $start -end_time $end
    4) report power # This gives expected result
    5) report pwer -mode myode # Result same as if no annotation
    6) report power # The VCD annotation data has been lost -> incorrect annotation data
    Note that when I perform command 5, it looks like a reset_design is performed and VCD data is lost. This is confirmed by repeating the report power (without mode) where I see incorrect results.
    Steven.
  • Fotios Nt
     Hi steven,
    This is somewhat strange, could you please file a case in support.cadence.com ?
    Fotis
  • moogydmaxim
    Hi Fotis,
    Thanks for the feedback - it's good to have confirmation that what I am trying to work should work :-)
     When time permits, I will try with a later version of RC, and then I will pass the issue to our central EDA group, who will check further.
    Thanks again,
    Steven
