  2. Mixed-Signal Design
  3. mixed-signal AMS simulation error
  • Replies 11
  • Subscribers 66
  • Views 28029
apple419
apple419 over 12 years ago
   I was trying to do a simple mixed-signal simulation with AMS in Cadence ADE environment (6.15).
   In the setup there are two inverters. One inverter A has schematic view and the other inverter B has Verilog view. The Config view is created.
   In the hierarchy editor form, correct views are set (A has schematic view and B has verilog view).
In ADE, the ams is selected as the simulator. The ConnRules_3V_full_fast is selected as the connect rule. The OSS-based netlister with irun is slected.
   When I started a transient simulation, the simulation log shows the following error and the simulation stopped.
   irun: *E,BDOPT: Unknown option -rnm_partinfo
   Anyone have any idea what this error is about?  Is there anything I missed in the setup?
Thank you for the help!
Regards
    Which version of INCISIVE are you using? I saw one report of this with a customer using IC616 and INCISIV12.1 - and the problem did not occur if they used INCISIV12.2. Also if they did a Netlist->Recreate it went away too (using INCISIV12.1).
    And which subversion of IC6.1.5 (Help->About in the CIW will tell you)?
  • apple419
    Andrew,
        I am using inciciv-12.10.006. The Cadence version is ic6.1.5-64b.500.17.
        I tried this: in ADE, Simulation -> Netlist -> Recreate, then Run. The error still exisits.
     Following is the irun.log:
    irun: 12.10-s006: (c) Copyright 1995-2012 Cadence Design Systems, Inc.
    TOOL: irun 12.10-s006: Started on Oct 08, 2013 at 07:02:02 MST
    irun
    -f irunArgs
    -clean
    -UNBUFFERED
    -errormax 50
    -status
    -nowarn DLNOHV
    -nowarn DLCLAP
    -v93
    -incdir /home/users/wangx/rechips/
    -timescale 1ns/1ns
    -discipline logic
    -delay_mode None
    -novitalaccl
    -access r
    -noparamerr
    -amspartinfo ../psf/partition.info
    -rnm_partinfo
    -modelincdir /home/users/wangx/rechips/
    ./spiceModels.scs
    ./amsControlSpectre.scs
    -input ./probe.tcl
    -run
    -exit
    -ncsimargs "+amsrawdir ../psf"
    -simcompatible_ams spectre
    -name test02:config
    -amsconnrules ConnRules_3V_full_fast
    +define+CDS_SELECT_CRS
    +define+CONNRULES_3V_FULL_FAST
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/ConnRules_3V_basic/connect/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/L2E_2/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/E2L_2/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/Bidir_2/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/E2R/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/R2E_2/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/ER_bidir/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/R2L/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/L2R/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/RL_bidir/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/L2E_2_CPF/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/Bidir_2_CPF/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/E2L_2_CPF/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/R2L_CPF/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/L2R_CPF/module/verilog.vams
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/RL_Bidir_CPF/module/verilog.vams
    ./netlist.vams
    -f ./textInputs
    /home/users/wangx/rechips/verilog_test/inv_vlog/verilog/verilog.v
    ./cds_globals.vams
    -l ../psf/irun.log
    irun: *E,BDOPT: Unknown option -rnm_partinfo.
    TOOL: irun 12.10-s006: Exiting on Oct 08, 2013 at 07:02:02 MST  (total: 00:00:00)
    In the CIW, can you enter:
    _amsUISimFeatures->ncelab_rnmpartinfo
    and see what it returns? Also can you do:
    getShellEnvVar("AMS_FEATURE_FILE")
    and see if that returns anything (I'm wondering if the AMS_FEATURE_FILE UNIX env var has been set and is pointing to an INCISIV12.2 installation hierarchy).
    Finally, if the first returns t, and the AMS_FEATURE_FILE isn't set, can you take a look in:
    /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/files/amssim.dat
    if you do "grep rnm  /pkg/incisiv-12.10.006/tools.lnx86/affirma_ams/etc/files/amssim.dat" and see if it returns a line with "rnmpartinfo".
  • apple419
    Andrew,
        In the CIW, I entered:
        then it returned: nil
        Then I entered:
        It returned: nil
         Then I entered  following in a terminal window:
         It retured nothing.
         Does this mean I have some fundamental setup issue?
    That's odd. Your setup looks normal - the above tells me that you've not pointed it to an erroneous feature file (you should not set $AMS_FEATURE_FILE except if told to by Cadence for some reason), and it wasn't something wrong with the feature file (that's the amssim.dat) in the specific subversion you're using.
    I can't see how it would netlist -rnm_partinfo without this though. Having netlisted in ADE, can you enter this in the CIW?:
    _amsOSSIrunObj->feature_ncelab_rnmpartinfo
    Anyway, the solution is probably just to switch to using INCISIV12.2 - since that version does support the -rnm_partinfo option on irun.
    Kind Regards,
  • apple419
    yes, it looks not normal.
    When I do simulation->netlist->recreate, the CIW window shows AMS netlisting has completed successfully.
    As you mentioned, after entered
    it retured t
    By the way how to switch to incisiv 12.2? How do i tell if incisiv 12.2 is installed?
    When I start the virtuoso I use: virt +incisiv xh035, where xh035 is the process I use.
     Following is the netlist it created:
    // PLEASE DO NOT EDIT OR COMPILE THIS FILE.
    // IT IS MEANT FOR VIEWING PURPOSE ONLY.
    // All files for configuration: (re353 test02 config)
    // AMS netlist generated by the OSS based AMS netlister
    // IC subversion:  IC6.1.5-64b.500.17
    // IUS version: 12.10-s006
    // Copyright(C) 2005-2009, Cadence Design Systems, Inc
    // User: wangx Pid: 18069
    // Design library name: re353
    // Design cell name: test02
    // Design view name: config
    // Solver: Spectre
    `include "disciplines.vams"
    `include "userDisciplines.vams"
    // Library - xh035_std_v01, Cell - ginva, View - schematic
    // LAST TIME SAVED: Oct  1 08:44:01 2013
    // NETLIST TIME: Oct  8 13:05:29 2013
    `timescale 1ns / 1ps
    (* cds_ams_schematic *)
    module ginva (O, I);
    parameter Wp=7e-07;
    parameter Lp=3.5e-07;
    parameter Wn=7e-07;
    parameter Ln=3.5e-07;
    output  O;
    input  I;
    wire (*
    integer inh_conn_prop_name = "ggnd";
    integer inh_conn_def_value = "cds_globals.\\vss! ";*)
    cdsNet0;
    wire (*
    integer inh_conn_prop_name = "gpwr";
    integer inh_conn_def_value = "cds_globals.\\vdd! ";*)
    cdsNet1;
    \pmos #(.m("(1)*(1)"), .w(Wp), .l(Lp), .ad(0.85u*(Wp)), .as(0.85u*(Wp))
        , .pd(0.85u*2+(Wp)), .ps(0.85u*2+(Wp)), .nrd(0.3u/(Wp)),
        .nrs(0.3u/(Wp)), .par1("(1)"))
    (* integer passed_mfactor = "m"; *)
    M0 (O, I, cdsNet1, cdsNet1);
    \nmos #(.m("(1)*(1)"), .w(Wn), .l(Ln), .ad(0.85u*(Wn)), .as(0.85u*(Wn))
        , .pd(0.85u*2+(Wn)), .ps(0.85u*2+(Wn)), .nrd(0.3u/(Wn)),
        .nrs(0.3u/(Wn)), .par1("(1)"))
    M1 (O, I, cdsNet0, cdsNet0);
    endmodule
    // Library - re353, Cell - test02, View - schematic
    // LAST TIME SAVED: Oct  8 12:40:35 2013
    module test02 ();
    ginva #( .Wn(7e-07), .Lp(3.5e-07), .Ln(3.5e-07), .Wp(7e-07) ) I0 (
        .O(ginva_o), .I(net1));
    myinv I6 ( .o(dinv_o), .in(ginva_o));
    vsource #(.type("pulse"), .val0(0), .val1(3), .period(1u), .delay(0),
        .rise(100n), .fall(100n), .width(500.0n)) V0 (net1,
        cds_globals.\gnd! );
    vsource #(.dc(3), .type("dc")) V2 (cds_globals.\vdd! ,
    vsource #(.dc(0), .type("dc")) V1 (cds_globals.\vss! ,
    endmodule
    // Verilog-AMS cds_globals module for top-level cell:
    //    re353/test02.
    // Generated by ADE.
    // Cadence Design Systems, Inc.
    // This is an autoGenerated file, any changes done to this file may get lost.
    module cds_globals;
    // Global Signals
       wire \vdd! ;
       wire \vss! ;
       electrical \gnd! ;
       ground \gnd! ;
    // Design Variables
    endmodule
    // This is the Cadence AMS Designer(R) analog simulation control file.
    // It specifies the options and analyses for the Spectre analog solver.
    simulator lang=spectre
    simulatorOptions options temp=25.0 tnom=27 scale=1.0 scalem=1.0 \
    reltol=1e-3 vabstol=1e-6 iabstol=1e-12 gmin=1e-12 rforce=1 maxnotes=5 \
    maxwarns=5 digits=5 pivrel=1e-3 checklimitdest=psf
    tran tran stop=5u save=none write="spectre.ic" writefinal="spectre.fc" \
    annotate=status maxiters=5
    # This is the NC-SIM(R) probe command file
    # used in the AMS-ADE integration.
    # Database settings
    if { [info exists ::env(AMS_RESULTS_DIR) ] } { set AMS_RESULTS_DIR $env(AMS_RESULTS_DIR)} else {set AMS_RESULTS_DIR "../psf"}
    database -open ams_database -into ${AMS_RESULTS_DIR} -default
    # Probe settings
    probe -create -emptyok -database ams_database {test02.ginva_o}
    probe -create -emptyok -database ams_database {test02.dinv_o}
    I can't see how this could be being set if it's not in the feature file. Very odd....
    The "virt +incisiv" is some wrapper scripts in your environment. Best to ask whoever is reponsible for installing software at your site.
    Kind Regards,
  • Asako
    Asako over 9 years ago
    how did you resolve this in the end ? I'm getting the same error...
    Clearly the simplest way to solve it is to use a newer version of INCISIVE. Which version are you using?
  • Asako
    INCISIV11. so, it's purely tool version issue ? I'll ask IT to upgrade it. Thanks a lot !
