  2. Mixed-Signal Design
  3. An Mixed-Sim(spectreverilog) Error: Component name (cdsNet0...
  • Subscribers 64
  • Views 2101
An Mixed-Sim(spectreverilog) Error: Component name (cdsNet0) not declared
Lynn Lou
Lynn Lou over 12 years ago
Dear All,
I am trapped by a  spectreverilog error for sometime. I cannot do tran simulation, and in the output log, it says:
    Error! Component name (cdsNet0) not declared   [Verilog-CNNOD]
             "saveDefs", 6:  test.top.I0.cdsNet0
Could anyone help me out of this? Thank you in advance.
    From doing a bit of hunting around, I think this can happen if you use escaped names (e.g. \a ) in textual views.
    But hard to be sure without seeing your data. Maybe you can contact customer support?
  • Lynn Lou
    Thanks a lot for your reply.
    Would you please explain a bit more about "escaped names" ? Is it just a net name with a slash before it? You mean the symbol views when you mention about the "textual views"? It seems I did not use the escaped names in the Verilog codes, and the symbols are automatically generated.
    Thank you very much.
    Best regards,
    Lynn
    An escaped name is one with a backslash before it - it allows normally illegal characters to be used - the name is escaped up to the next space.
    A textual view is a view such as functional or behavioral (for example). It's a view which contains the text of some Verilog code. It is not the symbol.
    As I said, contacting customer support is the best avenue here. That will avoid having to guess what your problem is.
