  2. Mixed-Signal Design
  3. DCO test using Verilog A "unexpected statement "{""
  • Subscribers 64
  • Views 3811
Yizhe Hu
Yizhe Hu over 10 years ago
Hi guys,
This is my testing code for DCO. I try to use spectre to do sp simulation.
Parametric Analysis change Vin every time, and then get the Dout (0V, or 1V thermometer code). Dout is used to control DCO Switch bank.
There is no problem with my Verilog-A, but spectre cannot detect "{", which appears in "parameter real valxx [64:0] = {0, 0...}."
How could I solve this?
Could you give other testing method?
  • Yizhe Hu
    Andrew Beckett
  • Yizhe Hu
    @Andrew Beckett
    Please post the Verilog-A code as an attachment or in the post itself. A picture of the code isn't much help - I'm not going to sit and type it in again to try this out.
    Also, please post the instance line in the input.scs (line 156 - ideally lines either side of it just to make sure) so that I can see what the instance line looks like. The error is in the spectre netlist, not in the Verilog-A.
    By the way, posting my name in a reply or sending me a friend request won't get me to respond any more quickly...
  • Yizhe Hu
    Thanks for reply.
    I have find the solution for this.
    the parameter array in Verilog-A should use { }.
    in spectre use [ ].
    So, if I choose the instance of Verilog-A, click q, and then pass parameter through CDF using [0 0 0... 0 1 1 1], it is ok.
    Yizhe
    Yizhe,
    This appears to be the same issue then that is discussed in this thread (which has been brought up again recently too).
