  2. Mixed-Signal Design
  3. Format of "VCD Info File"
  • Replies 16
  • Subscribers 64
  • Views 34629
pyohayo
pyohayo over 7 years ago
Does exist a document with examples on how to create  "VCD Info File" for a given "VCD File"?
    Andrew Beckett over 7 years ago in reply to pyohayo +1
    Without the data, it's pretty hard to debug this. You've only included part of the VCD file, and I don't know what your netlist looks like either. I think you've aliased the names incorrectly, probably…
  • pyohayo
    Well ... I've found a description in Appendix E of Spectre® Circuit Simulator and Accelerated Parallel Simulator User Guide
    and created vcd_info file according to the this document.
    Here is the content of the vcd_info :
    .voh 5.0
    .vol 0.0
    .scope simple_clock(bhv)
    .out clock
    where simple_clock(bhv) - the name of digital block entity(architecture) from which I creaed vcd.
    clock - the only output from the block.
    At the Virtupso side the schematic is very simple: only one component - resistor, connected to GND at one side, at other - to the floating net named "clock".
    When I run Spectre, I get the following:
    Notice from spectre during topology check.
    Only one connection to the following 2 nodes:
    0
    clock
    Error found by spectre during initial setup.
    ERROR (USIMPRS-17866): No Data read from the vcd file, please verify that the scopes are correct and there are in and/or out vectors specified.
    Fatal error found by spectre during initial setup.
    FATAL (SPECTRE-13004):
  • pyohayo
    pyohayo over 7 years ago in reply to pyohayo
    When trying the setup from previous message, I erroneously worked with wrong file.
    Here is setup that simulates, but still there is no connection between stimuli signal and node in Virtuoso schematic.
    The top of .vcd file:
    $comment
    TOOL: simvision(64) 12.10-s019
    $end
    $date
    Jul 01, 2019 15:18:55
    $end
    $timescale
    1fs
    $end
    $scope module simple_clock $end
    $var wire 1 ! clock1 $end
    $upscope $end
    $enddefinitions $end
    #0
    $dumpvars
    0!
    $end
    #50000000
    1!
    #100000000
    0!
    #150000000
    1!
    #200000000
    The content of vcd_info:
    .hier 1
    .voh 5.0
    .vol 0.0
    .scope simple_clock
    .out clock1
    Note from simulation log:
    0
    clock1
    As result - the clock1 is kept to 0.
    Any comments.
    The issue is that you should have used .in rather than .out. From the same document you referenced (right at the beginning):
    The signal directions are specified in the signal information file. To input signals, Spectre applies stimuli to the simulation. The values of the output signals are used to perform a vector check against the simulation results, and vector errors are generated if mismatches occur
    I've not really tried the checking capability with Spectre (I know I've used it with UltraSim in the past), but the key point here is that if you're expecting the signal to be driven, you must specify .in so that it's an input signal.
  • pyohayo
    pyohayo over 7 years ago in reply to Andrew Beckett
    Thanks Andrew,
    The case that interests me isn't mentionned in the fragment you quote. i.e. when digital stimuli in .vcd file are applied to Spectre simulator.
    Or such case isn't taken into consideration by Cadence.
    Anyway I've tried with .in.
    The same result
  • pyohayo
    Well, actually I don't understand what really happens ... I modify the content of the vcd_info and .vcd (e.g. change the name of signal) and rerun simulation, but simulator always shows the same message as if it dodn't see modifications.
    So after each modification should I close and reopen ADE ?
    Hit the stop button in ADE. Normally ADE (L) keeps spectre running and most likely it's not refreshing if the contents change.
    It does work with .in. If I use this:
    .hier 1
    .vih 5.0
    .vil 0.0
    .scope simple_clock
    .in clock1
    Then I get a signal called simple_clock.clock1 - i.e. a signal inside the hierarchical instance called simple_clock (which gets created if it doesn't exist in your design).You should also use vih/vil rather than voh/vol. It's not going to drive a top level signal called clock1. If you wanted that, you need to use .hier 0 instead. Or add:
    .alias simple_clock.clock1 clock1
    The checking of output vectors does indeed work with spectre (I just checked) - I get a file called input_tran.vecerr with the details of any mismatch between the signals marked as outputs and the actual signals in the simulation - so it's to check that the response is what you expect.
    For more details, look at the Rapid Adoption Kit Using VEC and VCD files in AMS and Analog Simulation in ADE
  • pyohayo
    Yes !!!
    Thanks Andrew !
  • pyohayo
    Andrew,
    When I try with real testbench the problem reappears.
    Here is definition section of .vcd:
    $scope module tb_top $end
    $scope module inst_as2005_left $end
    $scope module ANA $end
    $var wire 1 ! afe_pd $end
    $var wire 8 " cal_dac [7:0] $end
    $var wire 1 # cal_load $end
    $var wire 1 $ cal_on $end
    $var wire 1 % cal_readout $end
    $var wire 3 & cap [2:0] $end
    $var wire 3 ' comp1 [2:0] $end
    $var wire 3 ( comp2 [2:0] $end
    $var wire 51 ) grp1_adc [50:0] $end
    $var wire 1 * grp1_blo_on $end
    $var wire 1 + grp1_cds1 $end
    $var wire 1 , grp1_cds2 $end
    $var wire 1 - grp1_clk $end
    $var wire 1 . grp1_irst $end
    $var wire 1 / grp1_lpf_on $end
    $var wire 1 0 grp1_s1 $end
    $var wire 1 1 grp1_s2 $end
    $var wire 1 2 grp1_tr $end
    $var wire 3 3 ifs_cfg [2:0] $end
    $var wire 3 4 lpf_cfg [2:0] $end
    $var wire 1 5 lpw_on $end
    $var wire 1 6 ref_tft_pd $end
    $var wire 3 7 vcoarse [2:0] $end
    $upscope $end
    $upscope $end
    $upscope $end
    Here is vcd_info: (I tried with .hier 0 ... it doesn't work at all ... simulator stops with error "can't load vcd file" or something like this)
    .hier 1
    .vih 1.8
    .vil 0.0
    .scope tb_top.inst_as2005_left.ANA
    .alias tb_top.inst_as2005_left.ANA.grp1_blo_on grp1_blo_on
    .alias tb_top.inst_as2005_left.ANA.grp1_cds1 grp1_cds1
    .alias tb_top.inst_as2005_left.ANA.grp1_cds2 grp1_cds2
    .alias tb_top.inst_as2005_left.ANA.grp1_clk grp1_clk
    .alias tb_top.inst_as2005_left.ANA.grp1_irst grp1_irst
    .alias tb_top.inst_as2005_left.ANA.grp1_lpf_on grp1_lpf_on
    .alias tb_top.inst_as2005_left.ANA.grp1_s1 grp1_s1
    .alias tb_top.inst_as2005_left.ANA.grp1_s2 grp1_s2
    .alias tb_top.inst_as2005_left.ANA.grp1_tr grp1_tr
    .alias tb_top.inst_as2005_left.ANA.lpw_on lpw_on
    .alias tb_top.inst_as2005_left.ANA.afe_pd afe_pd
    .alias tb_top.inst_as2005_left.ANA.ref_tft_pd ref_tft_pd
    *.alias tb_top.inst_as2005_left.ANA.ifs_cfg[2:0] ifs_cfg<2:0>
    *.alias tb_top.inst_as2005_left.ANA.cap[2:0] cap<2:0>
    *.alias tb_top.inst_as2005_left.ANA.comp1[2:0] comp1<2:0>
    *.alias tb_top.inst_as2005_left.ANA.comp2[2:0] comp2<2:0>
    *.alias tb_top.inst_as2005_left.ANA.vcoarse[2:0] vcoarse<2:0>
    *.alias tb_top.inst_as2005_left.ANA.cal_dac[7:0] cal_dac<7:0>
    .alias tb_top.inst_as2005_left.ANA.cal_load cal_load
    .alias tb_top.inst_as2005_left.ANA.cal_on cal_on
    .alias tb_top.inst_as2005_left.ANA.cal_readout cal_readout
    .alias tb_top.inst_as2005_left.ANA.*[*] *<*>
    .out grp1_adc<50:0>
    .in grp1_blo_on
    .in grp1_cds1
    .in grp1_cds2
    .in grp1_clk
    .in grp1_irst
    .in grp1_lpf_on
    .in grp1_s1
    .in grp1_s2
    .in grp1_tr
    .in lpw_on
    .in afe_pd
    .in ref_tft_pd
    .in lpf_cfg<2:0>
    .in ifs_cfg<2:0>
    .in cap<2:0>
    .in comp1<2:0>
    .in comp2<2:0>
    .in vcoarse<2:0>
    .in cal_dac<7:0>
    .in cal_load
    .in cal_on
    .in cal_readout
    With .hier 1 it runs but in Spectre log I see this:
    No connections to node `tb_top.inst_as2005_left.ANA.grp1_adc<50>'.
    No connections to node `tb_top.inst_as2005_left.ANA.grp1_adc<49>'.
    No connections to node `tb_top.inst_as2005_left.ANA.grp1_adc<48>'.
    No connections to node `tb_top.inst_as2005_left.ANA.grp1_adc<47>'.
    No connections to node `tb_top.inst_as2005_left.ANA.grp1_adc<46>'.
    Further occurrences of this notice will be suppressed.
    Only one connection to the following 71 nodes:
    cal_daq<7>
    cal_daq<6>
    cal_daq<5>
    cal_daq<4>
    cal_daq<3>
    No DC path from node `I8.DSLICE.CSA.ABLOOM.sleep' to ground, Gmin installed to provide path.
    No DC path from node `grp1_clk' to ground, Gmin installed to provide path.
    No DC path from node `cal_dac[7]' to ground, Gmin installed to provide path.
    No DC path from node `cal_dac[6]' to ground, Gmin installed to provide path.
    No DC path from node `cal_dac[5]' to ground, Gmin installed to provide path.
    Actually I don't know what is connected and what isn't because only part of "only one connection" notices is displayed.
    Does exist a way to display all of them ?
    Thanks.
    Without the data, it's pretty hard to debug this. You've only included part of the VCD file, and I don't know what your netlist looks like either. I think you've aliased the names incorrectly, probably. You have cal_daq<> and cal_dac[] names in the report - the single connection means that there's a single connection, so it's really not clear if it's connected properly from the messages alone.
    I'm sure this would be easy to solve with access to the data. If you can't share it here, please contact customer support.
  • pyohayo
     Thanks Andrew,
    I can share, but I didn't find a way to attach it ... only video/image types are accepted
