  2. Mixed-Signal Design
  3. AMS Simulation: Use SystemVerilog module instantiating other...
  • Subscribers 67
  • Views 9165
AMS Simulation: Use SystemVerilog module instantiating other submodules in SystemVerilog
Mathieu Chene
Mathieu Chene over 2 years ago
First, thanks for reading this post !
I am working on a mixed signal simulation using ADE explorer and AMS simulator.
In the top design I have a module A I want to instantiate as a systemVerilog object. in the sv file this module include a submodule B also defined in sv.
Both modules are defined in the same file
/* Start file*/
module A();
  B(ports...)
endmodule
module B();
description ....
endmodule
/*end file*/
When I generate the netlist it fails telling that B (here muxReadX) is not defined in config view ....
Then I tryed to use a separate sv file for B in to use the `include "pathToB" method (adding the path to B in the ams simulator option) but I have the same error.
/* Start file*/
`include "path_to_B"
module A();
  B(ports...)
endmodule
/*end file*/
Then I created a library named SYSTEMVERILOG_lib in which I store the sv description. I added it in the library list of my config view but it still does not find it (address_decoder is found and I do not know why it is different here)
Do you have any idea on how to solve this ?
I have also to precise that I do not have this issue with sv module that does not call submodule.
I am using IC23.1
I have already seen this post but it was not helpful:
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006DdhMUAS&pageName=ArticleContent
 How to include Verilog functional files in Virtuoso Hierarchy Editor for SDF Simulation
 In AMS simulation, for verilog, how to use a module in a top module?
I would be glad to give more precision if needed.
Thank you in advance for your help
Mathieu
  • tpylant
    tpylant over 2 years ago
    How about creating a systemverilog cellview for 'B' that has the module B code in it?
    Tim
  • Mathieu Chene
    Mathieu Chene over 2 years ago in reply to tpylant
    Thank you for your answer. I did it, I have just created a dedicated library SYSTEMVERILOG_lib to store these cell views . It works for one module (address_decoder) but muxReadX is not linked...
    Andrew Beckett over 2 years ago in reply to Mathieu Chene
    I'm not sure how you expect anyone to know why address_decoder is any different from muxReadX given that you've not shared either...
  • Mathieu Chene
    Mathieu Chene over 2 years ago in reply to Andrew Beckett
    I haven't shared it because it's not the main point of my question. My main concern is why doesn't the configuration view take into account the submodules described in the same systemverilog view as the main module? As this is accepted by xcelium, and virtuoso's systemverilog view is extracted using xrun as well, I don't really understand the difference on how the file is ‘parsed’ by the config view (I don't know if I'm clear).
