  2. Allegro X APD
  3. Differences between APD & CDNSIP
  • Subscribers 68
  • Views 8813
sidm
sidm over 5 years ago
Hi All,
Can anyone please help me understand the main differences between APD & CDNSIP apart from the difference in their file formats ? When is one used over the other ?
Asking mainly from the point of view of 17.2 version of Allegro and not 17.4
Thanks in advance.
  • sidm
    Hi All,
    request for some feedback on this please.
    thanks
  • masamasa
    masamasa over 5 years ago in reply to sidm
    r u talking about differences between apd and sip?
    sip has die stack editor and advanced sip options, which cadence calls co-design and which apd does not.
  • sidm
    sidm over 5 years ago in reply to masamasa
    thanks for the reply, yes I am asking for about differences between apd and sip. Where can this die stack editor be used using CDNSIP ?
  • masamasa
    i do not use sip so i do not know much.
    but these might help u.
    https://www.cadence.com/content/dam/cadence-www/global/en_US/documents/tools/ic-package-design-analysis/sip-digital-design-ds.pdf
    https://docplayer.net/2662684-Cadence-sip-design-connectivity-driven-implementation-and-optimization-of-singleor-multi-chip-sips.html
    http://docplayer.net/55163741-Cadence-sip-rf-design.html
    https://community.cadence.com/cadence_blogs_8/b/pkg/posts/die-stacking-in-allegro-package-designer
    https://community.cadence.com/cadence_blogs_8/b/pkg/posts/vary-your-assembled-packages-not-your-databases
    https://community.cadence.com/cadence_technology_forums/f/ic-packaging-and-sip-design/25833/die-height-in-stacked-die
  • sidm
    thank you very much for sharing the links
