  3. Vias under package
  • Subscribers 167
  • Views 16406
Vias under package
nutron
nutron over 6 years ago
So i have this footrpint where the manufacturer suggests thermal vias under the package as shown in this picture....
I used Ultra librarian to create the footprint for ORCAD. The problem is that it turned each via into a pin though .....
I would like to know if this is the way it is done in ALLEGRO or if there is a better way to place vias under a package footprint?
  • RFinley
    RFinley over 6 years ago
    I thought heat was best conducted through the vias into the (larger/continuous) ground planes.  FLIR analysis of test boards has me suspecting better heat conductivity on surface pours under the device..   I always create SMD footprints and add stitching vias as we don't always use parts at full power, so a fixed number of vias doesn't pay off for us.  Vias are always part of the board object.
  • Dale Peterson
    Dale Peterson over 6 years ago
    Just add mechanical thru pins that look like your vias to your part in the library.
    Cheers
  • Lock2002
    Lock2002 over 6 years ago
    Ultra Librarian is okay for basic parts, but this is far from basic. It looks like it might work electrically but it's not a good design. I would create it manually. Add the vias manually as well.
  • Lock2002
    Lock2002 over 6 years ago in reply to Dale Peterson
    mechanical pins will be electrically isolated. I would assume these need to be connected to a return plane
  • nutron
    I got the part file from TI , they recommended using ultra librarian to export to CADENCE.
    I just used ultra librarian because this part is on the complex side. Basic parts are done easily in ORCAD.
    I agree with you guys on adding the vias manually . It gives one better control.
