  3. Obtain all 'shorting' errors via skill
  • State Verified Answer
  • Replies 11
  • Subscribers 22
  • Views 9885
khuranav007
khuranav007 over 4 years ago
Is there a way to filter 'shorting' errors from list of all DRCs in the design using Allegro Skill?  We short differently named nets together which leads to DRCs - is there a way to obtain a list of these errors (DRCs) as a result of shorting nets by the way of SKILL?  We do not add NET_SHORT property to suppress these DRCs.
Thanks!
  • DE202408202727
    DE202408202727 over 4 years ago in reply to khuranav007 +2 verified
    It's not difficult: drcs = setof(drc, axlDBGetDesign() ->drcs, drc ->type == "NET SPACING CONSTRAINTS" && zerop(axlMKS2UU(drc ->actual))) foreach(drc, drcs netnames = mapcar(lambda((vio), vio ->net …
  • RFinley
    0 RFinley over 4 years ago
    Will this help?
    community.cadence.com/.../skill-method-to-optimize-netlist-pin-assignments-during-routing-using-allegro-orcad
  • khuranav007
    0 khuranav007 over 4 years ago in reply to RFinley
    I don't know how this will help.
  • DavidJHutchins
    0 DavidJHutchins over 4 years ago
    I'm not sure if RFinley's post will help, since it's it's at the schematic level...
    From the Allegro standpoint, I think you would need to look at the 'drc errors' for 'Net Spacing Constraints' where the actual spacing value is 0, then add this drc to the list of errors...
  • DE202408202727
    0 DE202408202727 over 4 years ago
    You could certainly waive them using Skill
  • khuranav007
    0 khuranav007 over 4 years ago in reply to DE202408202727
    Hi Dave,
    Waiving a DRC is not the goal.  The goal is to find 'shorting' errors by the way of Skill.
    Thanks!
