  3. smallest text
  • Replies 16
  • Subscribers 167
  • Views 24453
smallest text
docb
docb over 10 years ago
I am using default text block sizes for reference designator silkscreen.
In your experience, can all board houses all print text block 1, which is 16x25?
  • oldmouldy
    oldmouldy over 10 years ago
    I guess it depends what you mean by "print", if you mean "silk screen printing", that would almost certainly be "none" since silk screen details are typically 8Mil, 0.2mm, or 10Mil, 0.25mm, as a minimum, and the text lines need to fit "in the text block", 2x8=16, so two lines would merge and not be text. For the default text blocks, 1 and 2 would probably be reserved for any text in copper, maybe other "free text" in the design that is not printed, and, at least, text block 3 used for any text intended for silk screen.
  • SevenFortyOneB
    SevenFortyOneB over 10 years ago
    I typically use .7mm wide by .9mm high with a .15mm photo width as my smallest text. I get decent readability and no complaints from the US and China PCB houses I deal with.
  • docb
    I'm unclear to what it means when its says:
    text block 1 is width=16, height=25, line space =31
    Do they mean a square that the text fits inside? How does that translate to line width?
  • docb
    FWIW, I use TB2 for silkscreen all the time, and it prints fine. That's 23x31. I hoped to use TB1 for this tiny PCB.
  • SevenFortyOneB
    "Do they mean a square that the text fits inside?"
    More or less - yes.  Line width is controlled by the "Photo Width" column.  Line Space, I believe, is the space between two lines (rows) of text.
    Your PCB house may change the "photo width" slightly to suit their manufacturing process.  You may want to check with them to see what their thinnest width/smallest text size capability is.
    I'd think if you made the text much smaller than 23x31 it would be hard to read without magnification even if it comes out "clean".
