  2. Sigrity
  3. Got Questions on Sigrity? Let’s Answer Them—LIVE on Wednesday...
  • Replies 17
  • Subscribers 22
  • Views 4172
Got Questions on Sigrity? Let’s Answer Them—LIVE on Wednesday, June 24th
Renu Vibha
Renu Vibha 5 months ago
Curious about the latest features? Facing real-world design challenges you’d like to crack faster?
This is a much awaited interactive live session with Cadence experts to get the answers you need—right when you need them.
Join us here on June 24, 2026 at 7:30 – 8:30 PM IST
Topics
  • PCB & IC Package S-Parameter Model Extraction
  • PDN Voltage Drop Analysis
  • High-Speed Design Simulation
This is your opportunity to:
  • Ask live questions
  • Learn from real use cases
  • Exchange insights with peers
Bring your challenges. Share your perspective. Be part of the conversation.
  • ShivaShankarM
    ShivaShankarM 4 months ago in reply to CF202606104231 +1
    Engineers use field solvers because real designs involve complex 3D electromagnetic interactions, coupling, and PDN effects that simple rule-based calculations cannot accurately capture.
  • ShivaShankarM
    0 ShivaShankarM 4 months ago in reply to EDA Star
    In Sigrity PowerDC, electrical and thermal effects are analyzed using its electro-thermal (ET) simulation capability, which is essential because temperature directly impacts copper resistance and hence IR drop. PowerDC first solves the DC current distribution and IR drop, computes the resulting Joule heating, updates the copper conductivity/resistance based on temperature, and then re-solves the electrical network. This iterative process continues until both temperature and voltage results converge.
    The key outputs are temperature hotspots, current density, copper temperature rise, resistance increase, and the resulting IR drop/voltage at sinks, allowing you to directly quantify how self-heating impacts power delivery.
  • EDA Star
    0 EDA Star 4 months ago in reply to ShivaShankarM
    THank you...
    Sometimes in high-current designs, the loop keeps heating up copper, the resistance keeps rising, and the simulation fails to converge (it errors out). When PowerDC fails to reach equilibrium, what are the best design steps to fix this thermal runaway issue?
  • ShivaShankarM
    Good question, EDA Star!
    Cadence provides a Clarity 3D Cut-and-Stitch flow, where EM-critical regions (such as BGA breakouts, vias, package escapes, etc.) can be solved using the Clarity 3D FEM solver, while the remaining layout is solved using PowerSI's hybrid extraction engine.
    To avoid introducing artificial discontinuities, the Clarity and PowerSI regions are stitched together at consistent electrical boundaries with matching signal/reference definitions. The stitched model is then validated using metrics such as TDR continuity, impedance correlation, and IL/RL consistency before performing system-level simulations.
    The resulting composite model can be analyzed in Topology Workbench/SystemSI for eye diagrams, jitter, SSN/PDN analysis, timing margin evaluation, and SerDes compliance verification.
  • EDA Star
    Hmmm...This helps... Thank you !
  • ShivaShankarM
    If an electro-thermal simulation fails to converge, it's often an indication of a real design issue rather than just a simulation issue. The first things you should investigate are current-density hotspots, excessive IR drop, localized temperature rise, and PDN bottlenecks.
    Typical fixes include:
    • Increasing copper width/thickness
    • Adding more vias or parallel current paths
    • Improving cooling (thermal vias, heatsinks, airflow)
    • Reducing load concentration and spreading current more evenly
    In PowerDC, focus on regions showing the highest current density, temperature rise, and resistance increase, as these are usually the root causes preventing convergence.
