  3. Innovus+ Platform: Now You Can Synthesize Your Design Using…
P Saisrinivas
P Saisrinivas
cadence latest
Synthesis to Timing Signoff
Digital Design and Signoff
Innovus Implementation System
Innovus+ Synthesis
integrated signoff
AI Assistant
3DIC
Cadence Online Support
PPA Improvement
RTL-to-GDSII
training
Cadence training
Digital Implementation
Innovus+ platform
Innovus
implementation
physical design
Genus Synthesis Solution
productivity
Synthesis
Innovus+
Innovus+ Platform: Now You Can Synthesize Your Design Using Innovus!
29 Jan 2026 • 3 minute read
Are you looking for a single integrated platform that runs both synthesis and implementation of your IC? Or if you are looking for fast and efficient design closure across a wide range of process nodes?
"No worries, the Innovus+ platform incorporates Innovus synthesis and Innovus implementation capabilities, all integrated into one unified environment for outstanding ease of use and power, performance, and area (PPA) results"
In the fast-paced world of IC Chip Design using ASIC flow, you need synthesis that matches your ambition—fast, precise, and fully integrated. Innovus+ delivers exactly that, with its platform-native/advanced synthesis engine designed for speed and scalability. Innovus+ Synthesis can be used standalone to generate logical/physically aware netlists ready for handoff to other design teams.
The race to tapeout at advanced nodes is defined by exploding design size, multi-corner/multi-mode (MCMM) complexity, and increasingly tight PPA targets. Teams often lose weeks ping‑ponging between disconnected synthesis and place‑and‑route iterations, wrestling with correlation gaps that derail schedules and inflate costs.
Innovus+ changes that.
It’s a unified, physically aware synthesis-to-implementation flow that aligns front-end and back-end decisions; so you converge faster, with predictable, signoff-quality results. Whether you’re driving a performance-first SoC, a power-sensitive wearable, or a 3D‑IC, Innovus+ brings the engines, integration, and automation to make closure repeatable and boring (in the best way).
This Innovus+ license is available starting from Innovus product release v25.1 and later versions
Benefits of the Innovus+ Platform
Innovus+ puts everything you need in one place. Run advanced synthesis alongside placement, routing, and optimization—without exports or tool switches. This unified approach means quicker iterations, sharper insights, and superior power, performance, and area (PPA) results.
Key benefits include:
  • Scalable, massively parallel architecture with multicore and distributed processing support
  • Unified RTL‑to‑GDS flow with common database, scripting, GUI, and shared physical/AI engines for predictable, high‑PPA closure
  • Full foundry and advanced‑node support, including angstrom‑class GAA and mixed‑signal interoperability via OpenAccess/Virtuoso
  • Signoff‑accurate in‑design verification, plus integrated LLM assistant for faster analysis and debug
  • Native integration with Cadence Cerberus AI Studio for agent-driven block and SoC implementation
Want to Dive Deep Into the Entire Innovus+ Flow?
To learn more about this Innovus+ flow, enroll in our free Innovus+ Synthesis and Implementation Flow with Stylus Common UI v25.1 training course.
If you don’t have an ASK account, you can register using this link and complete the requested information.
A Digital Badge is also available for this training.
If you want to share this and other great Cadence learning opportunities with someone else? Tell them to subscribe.
Hungry for training? Choose the Cadence Training Menu that’s right for you.
For questions and inquiries, or registration issues, reach out to eur_training@cadence.com.
Related Blogs
Digital Design Highlights: New Training, Blogs, Videos, and Badges 2025
Mini Clips, Mini Videos, Mega Crave: Why Short Reels Dominate Screens
Did You See? Mandarin Subtitles Are Live for Innovus Training—Here’s Your Start
RTL-to-GDSII Backend Webinar: Couldn’t Make It? We Saved You a Front Row Seat
Training Insights Webinar: Designing a Complete Chip Using the RTL-to-GDSII Flow - Digital Design - Cadence Blogs - Cadence Community
RTLtoGDSII: Creativity meets Engineering in Chip Design - Digital Design - Cadence Blogs - Cadence Community
RTL-to-GDSII Flow: I Am Not a Tool but Can Help You Implement Your Entire Design!
Training Bytes: They May Be Shorter, But the Impact Is Stronger!
Training Insights Accelerated Learning–The More You Know, the Faster You Go
Related Training Bytes
How to Run the Synthesis Without DFT? (Video)
RTL-to-GDSII Flow for ASIC Design Using Cadence Tools (Webinar) (Video) [CC]
Demo: How to Set Up the AI Assistant in the InnovusTm Implementation System (Video)
Demo: How to Highlight the Timing Path in Innovus Implementation System (Video)
Demo: How to Display Unplaced Macros in Innovus Implementation System (Video)
Demo: Placing Pins Using Pin Editor Window In Innovus. (Video)
Demo: How to Fix Antenna Violations In the Innovus Implementation System (Video)
