  3. Training Insights - RTL-to-GDSII Lab: Just One Click to…
P Saisrinivas
P Saisrinivas
Physical verification
ECO
conformal
IMC
Static timing analysis
DFT
Genus
hold
rail analysis
Tempus
Routing
ASIC flow
LEC
drv
STA
Setup and Hold Analysis
Floorplanning
RTL-to-GDSII
Logic Design
coverage analysis
xrun
setup
logic equivalence checking
digital implementation
GDSII export
Innovus
digital full flow
physical design
Timing analysis
rtl2gds2
Power Analysis
xcelium
CTS
RTL2GDSII
Synthesis
Placement
Tempus Timing Signoff Solution
IR drop
physical implementation
Training Insights - RTL-to-GDSII Lab: Just One Click to Increase Your Confidence in Handling Tools!
16 Dec 2022 • 3 minute read
Are you struggling to run the RTL2GDSII labs? Want to speed up your learning time? No worries, watch the lab demos created for each module of the flow by clicking the  play button.
At the end of the Cadence_RTL-to-GDSII_Flow 4_0 online course is a lab manual that instructs and tests topics first introduced in the lecture.
Lab instructions are also available in video format to speed up the learning time. These demo videos will help you to perform each step quickly for the complete course and improve the learner's confidence in using all the tools.
The Cadence_RTL-to-GDSII_Flow 4_0 course was released a few months ago. Now you can also access the lab demos created for each module of the course through a channel video. Each video takes approximately three minutes to view.
RTL-to-GDSII lab demo videos
After watching the RTL-to-GDSII lab demos, you will be able to:
  • Code a design in Verilog as per the design specification provided.
  • Compile, elaborate, and simulate your design.
  • Synthesize your design.
  • Run a design for test flow.
  • Run equivalency checking at different stages of the flow.
  • Floorplan a design.
  • Run placement, optimization, clock tree synthesis, and routing on your design.
  • Run signoff checks to ensure that you can fabricate a chip.
  • Write out a GDSII file.
Want to learn more?
We can also organize this Cadence RTL-to- GDSII Flow training for you as a "Blended" or "live" training. Please reach out to Cadence Training for further information.
Register for the Online Training with the following steps:
  1. Log on to cadence.com with your registered Cadence ID and password.
  2. Select Learning from the menu > Online Courses.
  3. Search for Cadence_RTL-to-GDSII_Flow 4_0 using the search bar.
  4. Select the course and click the Enroll button.
Also, don't forget to obtain your Digital Badge after finishing the training.
Online courses
Cadence RTL-to-GDSII Flow v4.0 (Online)
Genus Synthesis Solution with Stylus Common UI v22.1 (Online)
Test Synthesis with Genus Stylus Common UI vGenus21.1 (Online)
Innovus Block Implementation with Stylus Common UI v22.1 (Online)
Conformal Equivalence Checking v22.1 (Online)
Blogs
Training Insights - What Is IR drop? Is it Possible to Run IR-drop Analysis Using Innovus?
Training Insights - Dude, Where's My Software?
RTL-to-GDSII Flow: I Am Not a Tool but Can Help You Implement Your Entire Design!
Relax in Summer with Cooler IC chips and Ice-Cream! Do you want to Explore the Recipe?
Training Insights – Design Robustness Analysis Application: Aging-Aware STA
Training Bytes
How to Run Power Analysis and Analyze the Results in Innovus
How to Route a Design and Perform RC Extraction and Timing Analysis in Innovus
Power Planning and Power Routing
Creating Power Rings, Power Stripes, and Power Rails in Innovus Implementaion System
Innovus LP21_1 Power Analysis Demo
Signoff Considerations for Low-Power Designs
Implementing Low-Power Using InnovusTm Technology
How to run and interpret results generated by the Early Global Router in Innovus Implementation System
For more information on Cadence's digital design and signoff products and services, visit www.cadence.com.
Happy learning! Thank You.
