  3. Using Verilogin
  • Views 19178
Using Verilogin
dinac
dinac over 17 years ago
hi all,
I am new to cadence, i am trying to simulate the digital-control logic along with the analog in cadence.
I synthesised my vhdl code to verilog netlist using design-compiler, using standard-cell library ".lib"
Now I am trying to import this into the cadence using verilogin. I did not understand the "Reference-Library" in verilogin . Should I create this Reference library from the .lib format standard-cell?  Is my flow right? I wanted to do a mix-simulation.
please help
Thanks a lot........
  • vjain
    vjain over 17 years ago
    Your standard library should be included in the Library manager before VerilogIn. The name of the "Reference-Library" is the name of the standard cell library as mentioned in Library manager.
  • dinac
    hi vjain,/all
    Thanks for your reply,.
    i did define the library ".lib" location in cds.lib. but when i parse this verilog netlist i get few errors.
    VerilogIn: *W,31 => Module X in FSM_file  not defined.Module FSM_file will be imported as functional.
    VerilogIn: *W,101 => Could not find symbol master for instance XY .Functional view won't have this instance.
    Please help
    thanks
  • vjain
    This is because there is come submodule of FSM_file which cannot be made with the information you have given. Functional import is done whenever the verilog file has behavioral description.
    Point to remember: Your verilogin file should be gate level netlist only. No behavioral or dataflow models should be there. I hope this should help.
  • dinac
    Thanks for your message....
    The Module X  referes to one my standard cells.
    I still have doubt in the Reference Library part, i do not see any cells in the Library Manager for this Reference Library, is it normal?
     thanks
  • dinac
    Hi
    Thanks for your reply.
    I guess i solved it
    1. Reference Library "CDK"
    2. -V option i provided the link of the standard-cell file in verilog format. ".V"
    I found few errors, mentioning the verilog
    " Verilog definition for module AND2 was not found. Using lib 'techlib' cell 'AND2' view 'symbol' as its symbol.
    But i guess I could discard this.
    Thanks a lot Again
    cheers
    dinac
