  3. FATAL (CMI-2010) : assertion failed in file 'param_shared...
  • Views 9909
FATAL (CMI-2010) : assertion failed in file 'param_shared.c' at line 2378
Chang
Chang over 17 years ago
I am updating cadence from v5141 to v6.1.2. , spectre version is 6.2.0.420, PDK is IBM cmrf8sf version 1.6. When I am doing simulation using spectre I got following massage:
FATAL (CMI-2010) : assertion failed in file 'param_shared.c' at line 2378.
FATAL (SPECTRE-21): Assertion failed.
Any idea to solve this problem? Thanks a lot.
    Andrew Beckett over 17 years ago
    My first suggestion would be to try a later spectre version. I did find one report of this (filed on 4th August, using the same version as you - and it was resolved by the user fixing the model files in an unspecified way...). So I suspect your problem has been resolved by now (unless it's a complete coincidence and the service request was not from your organisation).
  • KaiwalyaS
    KaiwalyaS over 10 years ago
    I am trying to plot Vth for various lengths in 180nm technology by varying the component parameter 'l' and doing dc analysis. I want to save the dc operating points and so I have defined a saveops.scs file and included it in the setup-->simulation files-->definition files. I am getting the following error. Do you know why I'm getting such an error ? Internal error found in spectre at l = 1e-06 during DC analysis `dc'. Please run `getSpectreFiles' or send the netlist, the spectre log file, the behavioral model files, and any other information that can help identify the problem to support@cadence.com.
    FATAL (CMI-2007): Error detected in file `psp102.c' at line 23391.
    I couldn't find a report of this, so you might want to do what the error message suggests and contact customer support.
    However, since you didn't mention the version you're using, I'd suggest you first try running with the latest MMSIM version (MMSIM15.1 or MMSIM14.1, the latest hot fixes of either) to see if this is something that's been fixed in a later release (and I've just not found a record of it).
