  3. Assura LVS error
  • Subscribers 136
  • Views 20079
Assura LVS error
jdgriggs
jdgriggs over 15 years ago
attached are screen shot of a simple inverter and the layout is drc clean but debug says there is a bad net when the nets match for both...I've done this design 4 times each from scratch and generate the same errors. I have tried using th permute tool but does not seem to help LVS issue. Your assitance is appreciated Regards James
  • jdgriggs
    also attached is the LVS error file....
    • inverter_lvs_report.txt
  • Quek
    Quek over 15 years ago
    Hi jdgriggs
    Your mos devices have been extracted as generic devices. Hence source and drain pins will not be automatically permuted. VXL layout pin permutation is not related to Assura LVS, hence it will not resolve the problem. You can resolve the problem as follows:
    a. In Assura LVS form, go to "avCompareRules"
    b. Select "Network"
    c. Select "swapPins" and add the following expression for schematic side:
    swapPins("pfet(Generic)" "(p S D)")
    d. Run LVS
    Best regards
    Quek
  • bartman
    bartman over 10 years ago
    I am having an LVS problem and I noticed this post.  I am not sure if anyone is still around (based upon the 2010 responses) to reply.
    At the end of the lvs report I have the following message:
    Preprocessing layout network phase 2
    *ERROR* Device 'pfet(Generic)' on Schematic is unbound to any Layout device.
    *ERROR* Device 'nfet(Generic)' on Schematic is unbound to any Layout device.
    *ERROR* UnBound devices found.
    Info: All devices must be bound or filtered for comparison to be run.
    Exiting nvn.
    It implies that I have devices in the schematic which cannot be matched to a layout device.  I have tried this in calibre and succeeded in getting a clean LVS; so I know the layout and schematic do match.  I would like to have assura working as well.  One possible issue is in the use of multiplicity; m>1 for every transistor in the schematic.   The LVS checks using assura for devices which have m=1 have worked.  Is it possible to fix this problem ?
    alan
  • Quek
    Quek over 10 years ago
    Hi Alan
    Would you please kindly start a new post for your issue? This thread has already ended in 2010.
    Quek
  • bartman
    Hi Quek,
    I created a new post this morning.  But, I am not sure if I did it correctly.  I am checking it now.
    best regards,
    alan
  • bartman
    The title of the new post, dated today: Assura LVS using: setenv OA_UNSUPPORTED_PLAT linux_rhel40_gcc44x
