  3. Problem in importing CDL/Spice netlist ...?
  • Replies 7
  • Views 12243
Prabhu The ICL
Prabhu The ICL over 15 years ago
 Hi! All,
  Once again I need your help. I am using Cadence IC514 version.
  I am trying to import a spice netlist using " CDL->Import " to make a corresponding schematic.
  I am able to import MOS transistors successfully but not capacitors & resistors.
  Here are the files that I am using for 'CDLIn' along with error output files ...
FileName:- map.in
devMap  := nfet nch
termMap := D D G G S S B B
propMap := w w m simM
addProp := model nch
devMap  := pfet pch
addProp := model pch
devMap     := capacitor nmoscap_25
termMap := PLUS PLUS MINUS MINUS
propMap := c c
addProp := model nmoscap_25
devMap  := phyres rppolywo_m
termMap := PLUS PLUS MINUS MINUS SUB BULK
propMap := r res w sumW l sumL addProp := model rppolywo_m
FileName:- test.sp
* SPICE NETLIST
*.BIPOLAR
*.RESI = 2000
*.RESVAL
*.CAPVAL
*.DIOPERI
*.DIOAREA
*.EQUATION
*.SCALE METER
*.MEGA
.PARAM
.SUBCKT nmoscap_25 PLUS MINUS
.ENDS
.SUBCKT rnpolywo_m PLUS MINUS BULK
.ENDS
.SUBCKT test vss vdd out
** N=3 EP=3 IP=0 FDC=2
X0 out vss nmoscap_25 lr=1e-06 wr=1e-06 $X=13640 $Y=900 $D=286
X1 vdd out vss rppolywo_m lr=1e-05 wr=2e-06 $X=770 $Y=450 $D=370
.ENDS
FileName:- ni.log
Reference Libraries...
basic
analogLib
tsmcN65
test_bt2
---- Device-mapping enabled ----
3 subckt(s) found in the netlist file.
  Subckt: test
  Subckt: nmoscap_25
Created the CV nmoscap_25->netlist_tmp.
ERROR (CDLIN-44): The sub-circuit 'nmoscap_25' does not have any instance (box element). Hence, its
schematic view will not be prepared.
Usage error.
TERED    0 ERRORS (   5 WARNINGS) DURING FILE INPUT
 FILE :./RUNS/test.sp
 *** NUMBER OF ELEMENT BOXES DEFINED     :     2
FileName:- ni.err
PROCESSING INPUT FILE: ./RUNS/test.sp
*** WARNING : *.EQUATION IS NOT SUPPORTED BY CDLIN. IGNORED
*/W* WARNING ***: NO ELEMENT INSIDE SUBCKT nmoscap_25 ** WARNING ** BOX NAME CAN NOT START WITH B,C,D,M,P,R AND CAN HAVE THREE CHARACTERS ONLY
*/W* WARNING ***: NO ELEMENT INSIDE SUBCKT rnpolywo_m ** WARNING ** BOX NAME CAN NOT START WITH B,C,D,M,P,R AND CAN HAVE THREE CHARACTERS ONLY
I hope this information is apropos.
Please, Can someone guide me to resolve this issue.
Thanks in Advance ...
Prabhakar. K
IC Layout Engineer
SoCtronics Tech. Pvt. Ltd.
e-mail: prabhu.usic@gmail.com
(-: 'GOAL' : Perhaps there's more than one way to reach it :-)
  • Quek
    Quek over 15 years ago
    Hi Prabhakar
    I think cdl-in should work if you make the following modifications to the netlist:
    a. Remove the empty subckt definitions for the primitive devices
    b. Change "X0" to "C0" and "X1" to "R1"
    Best regards
    Quek
  • Prabhu The ICL
    Hi! Quek,
    As you suggested I made the modifications to the
    netlist. All is going fine except when there are 2-terminal & 3-termianl
    resistors exist.
    If I use the same prefix (i.e. R) for both the devices CDLIN translating
    only 2-terminal device for both the statements.
    I mean ... consider the following two statements ...
    R0 vdd out vss rppolywo_m lr=1e-05 wr=2e-06 (==> 3-terminal res)
    R1 net1 net2 rppolywo l=1e-05 w=2e-06 (==> 2-terminal res)
    For the above two statements I am getting 'rppolywo' device.
    In addition to this issue can you clear me for one more issue .. If you
    don't mind ...!
    How to translate different types of MOS devices ...?
    Suppose, If I have pch, pch_mac, pch_25_mac etc .. devices which
    corresponds to model 'nfet' , How to write map file in this case. I mean
    how to
    differentiate them with prop 'subType' ...?
    Thanks & Regards
    Prabhakar. K
    IC Layout Engineer
    Hyderabad-INDIA
  • Quek
    Hi Prabhakar
    Here is what you need to do:
    a. Use a text editor to search and replace the different mos models (e.g. pch, pch_mac, etc) with 2 character models. E.g. PM, PV, etc. Cdl netlist in IC5141 uses the Dracula engine and only recognizes 2 character models.
    devMap := pfet pch
    propMatch := subtype PM
    propMap := w cdfW l cdfL
    devMap := pfet pch_mac
    propMatch := subtype PV
    b. For 3 terminal resistors, please use the following device map. You need to use "phyres" category device type instead of "resistor".
    devMap := phyres res3term
    termMap := PLUS PLUS MINUS MINUS SUB SUB
    propMatch := r 100
    propMap := r r w w l l
    Usually resistors in cdl netlist has a single value so you can use the "r" value to import the resistors.
    Best regards
    Quek
  • Prabhu The ICL
    Hi! Quek,
    I have succeeded in translating different type of MOS
    devices as you described ...
    But regarding resistors, I am keep getting the same issue ... In my case
    resistors in cdl netlist doesn't contain 'r' value .. So I can't import
    them using
    'r' value ... I tried to match other properties but in vain ... Is there
    any alternative to this ...
    Please, consider the following cdl netlist & dev-map files for your
    reference ...
    *.BIPOLAR
    *.RESI = 2000
    *.RESVAL
    *.CAPVAL
    *.DIOPERI
    *.DIOAREA
    *.EQUATION
    *.SCALE METER
    *.MEGA
    .PARAM
    .SUBCKT rppolywo_m PLUS MINUS BULK
    .ENDS
    .SUBCKT rppolywo PLUS MINUS
    .ENDS
    .ENDS
    .SUBCKT test1 I Y gnd vdd
    *.PININFO I:I gnd:I vdd:I Y:O
    CC1 net022 gnd nmoscap_25 lr=1u wr=1u m=1
    CC0 net024 gnd nmoscap_25 lr=1u wr=1u m=1
    RR1 net9 net022 gnd rppolywo_m lr=20u wr=2u m=1 mf=1 mismatchflag=0
    RR0 net5 net024 rppolywo l=10u w=2u m=1
    MM5 net5 I gnd gnd NM l=60n w=200n m=1
    MM4 net9 net5 gnd gnd NV l=60n w=200n m=1
    MM3 Y net9 gnd gnd NH l=280n w=400n m=1
    MM2 Y net9 vdd vdd PH l=280n w=400n m=1
    MM1 net9 net5 vdd vdd PV l=60n w=200n m=1
    MM0 net5 I vdd vdd PM l=60n w=200n m=1
    .ENDS
    devMap := nfet nch
    propMatch := subType NM
    propMap := m simM
    devMap := nfet nch_mac
    propMatch := subType NV
    propMap := m simM
    addProp := model nch_mac
    devMap := nfet nch_25
    propMatch := subType NH
    propMap := m simM
    addProp := model nch_25
    devMap := pfet pch
    propMatch := subType PM
    propMap := m simM
    propMatch := subType PV
    propMap := m simM
    addProp := model pch_mac
    devMap := pfet pch_25
    propMatch := subType PH
    propMap := m simM
    addProp := model pch_25
    propMap := c c
    devMap := resistor rppolywo
    propMap := r res w w l l
    Thanks & Regards
    Prabhakar. K
    IC Layout Engineer
    Hyderabad - INDIA
  • Quek
    Hi Prabhakar
    This is actually a common problem when importing resistors. If "r" is not available, we can also use the model name. Please make the following changes:
    a. In the netlist, make the following modifications:
    RR1 net9 net022 $SUB=gnd $[rppolywo_m] lr=20u wr=2u m=1 mf=1 mismatchflag=0
    b. Use the following in the device map:
    propMatch := model=rppolywo_m
    propMap := w w l l
    Best regards
    Quek
  • Prabhu The ICL
    Hi! Quek,
    I am very thankful to your kind & immediate response to
    my questions ... Now the problem has resolved ... Once again Thank you
    very much ...
    Regards
    Prabhakar. K
    IC Layout Engineer
    Hyderabad - INDIA
  • Quek
    Hi Prabhakar
    That's great. You are welcome. : )
    Best regards
    Quek
