  3. Cadence does not recognize technology file
  • Views 18076
Wonyoung
Wonyoung over 14 years ago
I created a library and I am trying to attach it to an existing technology library. The technology library shows up when I open the library manager. However, when I create a new library and select "attach to existing technology file", the technology library does not show up on the list. I am using Cadence 6.1.4. Any help is appreciated. Thanks.
Wonyoung
  • Quek
    Quek over 14 years ago
    Hi Wonyoung
    Perhaps the "tech.db" file in your tech library has been accidentally deleted. Would you please check the tech directory to see if there is a file named "tech.db"?
    Quek
  • Wonyoung
    Thanks so much for your reply, Quek. Yes the tech.db file is not there. Do I also need the data.dm file, or do I just need the tech.db file? It seems like this tech library is for Cadence 5. It works well in Cadence 5, but doesn't work for Cadence 6 since it doesn't have the tech.db and data.dm files.
  • Quek
    Hi Wonyoung
    data.dm for a library stores the library properties as explained in COS solution 11449754. If you translate your IC5141 techlib using "ciw: Tools->Conversion Toolbox->CDB to OpenAccess Translator", you will automatically get tech.db converted from tech.cdb file. A non-zero byte size data.dm will be created only if the translated IC5141 library has a prop.xx file. This is the equivalent of data.dm file for IC5141. data.dm is not absolutely necessary for a techlib to work unless the pdk stores some critical library properties in it and references those properties in its scripts.
    Best regards
    Quek
  • Wonyoung
    Thanks so much for your kind reply!
    Wonyoung
