  3. Poly layer density issue in the stream-out
  • Replies 7
  • Subscribers 133
  • Views 22081
Amel
Amel over 14 years ago
Hi all,
In order to cope with tsmc 0.18um requirements regarding poly and metal densities, I have used both dummy metals and dummy Poly to compensate the deficiency of my drawn metals and Poly in my design. By doing so, I achieved 0 DRC errors.
When I have exported my design to GDS and sent it to MOSIS  for  fabrication, I was surprised by the fact that the manufacturability review reveals a warning about poly1 density. I am confused since my design has passed the DRC with 0 errors.
So, I am wondering what could be the cause. is it possible that the dummy poly was not exported? Can anyone help me to overcome this problem?
Thanks in advance.
Amel.
  • Quek
    Quek over 14 years ago
    Hi Amel
    Here are a few possible causes of the discrepancies:
    a. The poly fill was not exported together with the design due to bad layer mapping
    => Correct the layer map file and redo stream out
    b. The poly fill was created using the wrong fill type (e.g. type "dummy" instead of type "drawing") and was not recognized by the foundry sign-off drc deck
    => Re-create the fill using the correct fill type and re-export the gds file
    c. You are using a different verification tool from the foundry (e.g. you are using Assura/PVS and tsmc uses another tool)
    => Get detail information from foundry on the density errors which they have encountered
    d. The density rules in your rule deck are coded differently from those in the foundry sign-off rule deck (due to different tools). E.g. your deck does not use windowing but density of each windows are checked in the sign-off rule deck
    e. You had run drc and gotten zero drc errors but had forgotten to enable the switch for density check
    => Enable density check and redo drc
    It would be best to first clarify with the foundry on the details of the density error. : )
    Best regards
    Quek
  • Amel
    Hi Quek,
    Thanks for your reply.
    I will answer your later questions and go back to the first suggestion:
    - I have used the appropriate purpose of the layer Poly1 that is “dummy” for the fill layer.
    c. You are using a different verification tool from the foundry (e.g. you are using Assura/PVS and tsmc uses another tool)!
    - I am using Assura as PDK we got recommends Assura in its setting.
    - I don’t know about this.
    - The densities are checked in my of DRC run.  I have encountered already densities problem but when I have added dummy layers, theses errors disappear and all switches are checked in my DRC.
    - Can you tell me more about how to do it?
    Thanks.
    Amel.
  • Quek
    Hi Amel
    The stream layer map file is named as "techlib.layermap" (e.g. tsmc018.layermap) in the technology library. You can check if "Poly1 dummy" is listed as one of the layers to export. Alternatively, you can import the gds file and check if the imported layout contains poly1 dummy shapes.
    I think the most important thing right now is to get detail information on the errors which your foundry is reporting. Otherwise you might not be doing the correct troubleshooting. : )
    Best regards
    Quek
  • Amel
    Hi quek,
    I have checked the stream out part in the techfile, it does exist.
    I have also checked the PIPO.log I got after GDSII stream-out. " Statistics Of Layers" reveals that poly1 dummy was exported as it can be seen bellow:
    Product   : Virtuoso(R) STREAM Out
    Program   : @(#)$CDS: pipo.exe version 5.1.0 06/20/2007 02:43 (cicsun11) $
    SubVersion: sub-version 5.10.41_USR5.90.69
    Started at: 08-Apr-2012  11:20:42
    User Name : chenouf
    Host Name : sapphire
    Directory : /home/chenouf/BTS_Strs
    CADENCE Design Systems, Inc.
    Cadence    Cadence    Stream   Stream
     Layer     Purpose    Layer   Datatype Rectangles Polygons Paths  Ellipses  Labels   Nodes
    METAL1     slot       16        2         0        0        396      0        0        0
    PIMP       drawing    7         0         416      4        0        0        0        0
    METAL6     drawing    38        0         3        107      0        0        0        0
    METAL2     slot       18        2         0        0        3468     0        0        0
    METAL2     drawing    18        0         86       0        0        0        0        0
    METAL4     drawing    31        0         1        0        0        0        0        0
    METAL6     slot       38        2         3624     0        0        0        0        0
    METAL5     dummy      33        1         334      0        0        0        0        0
    WELLBODY   drawing    103       0         30       0        0        0        0        0
    METAL4     slot       31        2         0        0        3460     0        0        0
    NIMP       drawing    8         0         421      8        0        0        0        0
    POLY1      dummy      13        1         168      0        0        0        0        0
    IP         drawing    63        63        0        0        0        0        917      0
    VIA56      drawing    39        0         31797    0        0        0        0        0
    CONT       drawing    15        0         18765    0        0        0        0        0
    METAL5     drawing    33        0         30       102      0        0        0        0
    CONT       pin        15        1         76       0        0        0        0        0
    ref        drawing    0         0         0        0        0        0        3        0
    VIA23      drawing    27        0         6615     0        0        0        0        0
    PAD        drawing    19        0         1        0        0        0        0        0
    METAL2     dummy      18        1         346      0        0        0        0        0
    METAL3     dummy      28        1         345      0        0        0        0        0
    LUPWDMY    drawing    255       1         178      0        0        0        0        0
    DIFF       drawing    3         0         1296     272      0        0        0        0
    LOGO       drawing    178       0         314      0        0        0        0        0
    NWELL      drawing    2         0         176      0        0        0        0        0
    METAL3     slot       28        2         0        0        3420     0        0        0
    METAL3     drawing    28        0         1        0        0        0        0        0
    METAL6     dummy      38        1         543      0        0        0        0        0
    METAL1     drawing    16        0         1259     1121     0        0        4        0
    METAL5     slot       33        2         63       0        3440     0        0        0
    VIA34      drawing    29        0         6613     0        0        0        0        0
    VIA12      drawing    17        0         6675     0        0        0        0        0
    VIA45      drawing    32        0         6615     0        0        0        0        0
    POLY1      drawing    13        0         641      265      3        0        0        0
    METAL4     dummy      31        1         346      0        0        0        0        0
       Summary Of Objects
       87778 Rectangles
        1879 Polygons
       14187 Paths
           0 Ellipses
         924 Labels
        1698 Instances
           0 Arrays
         189 Cells
           0 Nodes
    00:00:05 Elapsed time
    00:00:03 CPU time
       53533 Kbytes of memory
    *** There were 0 error and 2 warning messages ***
    The setup file's contents :
    streamOutKeys = list(nil
    'runDir "."
    'libName "lib_strs"
    'primaryCell "BTS_Structures"
    'viewName "layout"
    'outFile "/home/chenouf/Desktop/BTS_Structures.gds"
    'scale 0.001000
    'units "micron"
    'compression "none"
    'hierDepth 32
    'convertToGeo nil
    'maxVertices 200
    'refLib nil
    'libVersion "5.0"
    'checkPolygon nil
    'snapToGrid nil
    'simMosaicToArray t
    'caseSensitivity "preserve"
    'textCaseSensitivity "preserve"
    'lineToZeroPath "path"
    'convertDot "ignore"
    'rectToBox nil
    'convertPathToPoly nil
    'keepPcell nil
    'replaceBusBitChar nil
    'useParentXYforText nil
    'reportPrecision nil
    'runQuiet nil
    'comprehensiveLog nil
    'ignorePcellEvalFail nil
    'translateTopDown nil
    'errFile "/home/chenouf/Desktop/PIPO.LOG"
    'NOUnmappingLayerWarning nil
    'techFileChoice nil
    'pcellSuffix "DbId"
    'respectGDSIILimits nil
    'dumpPcellInfo nil
    'genListHier nil
    'cellMapTable ""
    'layerTable ""
    'textFontTable ""
    'convertPin "geometry"
    'pinInfo 0
    'pinTextMapTable ""
    'propMapTable ""
    'propSeparator ","
    'userSkillFile ""
    'rodDir ""
    'refLibList ""
    So, thanks again for your help.
    Amel.
  • Amel
    Hi all,
    I sent both my design DRC &  PIPO logfiles (for GDS2 stream-out) to Mosis service
    and it seems that  "Manufacturability Review does not handle Poly or
    OD dummy (fill) -- just the metal fill layers. Your OD and Poly dummy
    fill _will_ be manufactured; it just isn't being counted in our initial
    density measurement.
    It is on our list of things to fix, but, until that happens, you'll just have
    to ignore the warning(s) if you know that your filled layout is OK."
    I am releaved now and the issue is resolved.
    Amel.
  • Quek
    Hi Amel
    Thank you very much for sharing the information. : )
    Best regards
    Quek
  • Amel
    Hi Quek,
    You‘re welcome!
    Amel.
