  3. Verilog design in Cadence
  • Subscribers 130
  • Views 21883
kenambo
kenambo over 12 years ago
 Is there anyway that i can design a digital circuit in Virtuoso Schematic window...
And include the *.v file in the schematic capture window..
Thanks...
    Yes. You can create textual Verilog views (File->New->CellView and set the Type to "Verilog" - give the lib/cell/view a name). Then in the resulting editor create the Verilog representation. When you save and exit the editor, it will syntax check the view and then prompt you to create a symbol. You can instantiate this in the schematic.
  • Sali
    Sali over 12 years ago
     Hi all,
    I'm trying to build a voltage controlled curent source,I opened a new file with a verilogAMS text and write the following:
    module VCCS(p,n,pc,nc);
    inout p,n;
    input pc,nc;
    electrical p,n,pc,nc;
    parameter real gain=1;
    branch (p,n) iSrc;
    analog begin
    I(iSrc) <+ gain*V(pc,nc);
    end
    endmodulet pc,nc;
    and I created a symbol for it then I instantiate it on the schematic page but the output is always zero?
    Can any one help me?
    thanks
  • kenambo
     Thanks.. so i have to write a .v file and create a symbol.. am i right...
    What is the difference between this and the synthesis tool
    Thanks,,....
    inout p,n;
    branch (p,n) iSrc;
    analog begin
    end
    endmodulet pc,nc;
    Not sure why you posted this on the end of another thread, but the code you posted has typos in it - it wouldn't even syntax compile. I used a command-line example to try this out (having fixed the typos):
    `include "disciplines.vams"
    inout p,n;
    input pc,nc;
    branch (p,n) iSrc;
    analog begin
    I(iSrc) <+gain*V(pc,nc);
    end
    endmodule
    module test;
    electrical gnda;
    ground gnda;
    vsource #(.freq(1M),.ampl(0.5), .type("sine")) V1(n1,gnda);
    resistor #(.r(1k)) R1(op1,gnda);
    VCCS #(.gain(1m)) I1(op1,gnda,n1,gnda);
    endmodule
    And this together with testVCCS.scs :
    tran tran stop=2u
    I then ran "irun -gui testVCCS.scs testVCCS.vams" and I see these results (having problems uploading the picture, so I'll try again in a moment). Looks pretty OK to me.
    input pc,nc;
    A synthesis tool takes RTL (Register Transfer Level) code and converts it into a gate level representation. Writing a Verilog text view and simulating that just means that you're simulating what you wrote without it being synthesized. So it's a bit like asking what is the difference between an orange and a car - two completely different things.
  • Sali
    Thank you so much Andrew, and sorry for being late in my reply I had a problem accessing my cadence account ant it solved now. Thank you again, Sali
