  3. Specify custom tool instead of default viewer for log f...
  • Views 15964
Specify custom tool instead of default viewer for log files
Andreas W
Andreas W over 11 years ago
Is it possible to specify which program to use for viewing logs etc.? I know about the "editor" setting, but this does not apply do read-only files like logfiles. I found a thread from 2010 (http://community.cadence.com/cadence_technology_forums/f/38/t/17335) and wanted to ask if there where any changes since then.
My primary reason is that the builtin viewer is much less capable in terms of search/highlighting, configuring linebreaks etc. then e.g. gvim (which is quite ok, virtuoso does not need to be a competent text editor, but it would be nice to specify an alternative)
Best Regards,
Andreas
    Andreas,
    If editing or viewing VerilogA, Verilog or various other languages in IC616 ISR7 onwards, there is a language-sensitive viewer which is much smarter.
    For log files (e.g. the spectre log file), IC616 ISR9 onwards has a hypertext linked log file with colouring for warnings etc. The hypertext links allow you to open up referenced files, cross-probe to nodes and instances in the schematic, click on the analysis name and have it bring up the ADE analyses forms etc.
    If there are capabilities of these editors/log viewer, we are open to enhancing these further - please contact customer support.
    Obviously if you were to switch in an editor, you'd lose these useful hypertext features, so that's not currently supported for log files, and I think the direction is to improve the navigation around the log file built-in rather than supporting an external editor (which would lose some functionality straightaway).
  • Andreas W
    Andrew,
    Thank your for your quick answer, this will at least help with the readability of the files (till now I would just open the log folder and open the files manually, I wrote a few highlight files for vim to find stuff easier). I hope we will update to ISR7 soon, ATM we are still on ISR6, at least for the tech I'm working with.
    It doesn't help my more general gripe though, which is that I need different shortcuts in every application, which is why I'm trying to use the same tools in as many places as possible. E.g. if I open a Verilog file for rw, it will open in e.g. vim as I'm used to, but if I open the same file for read only it will look/feel differently.
    But the colors should make reading the files easier at least.
    Andreas
    Andreas - note that ISR7 has a built-in editor for Verilog, Verilog-A, Verilog-AMS etc - and this is the same as the viewer. So that should help. Of course, it may be that you don't find the editor full-featured enough yet...
  • Andreas W
    Ok, good to know, I'll have a look at that.
    Regarding the editor features: It's not so much the "lacking" features as simple the difference between all the tools which is the reason I try to stick with not that many different types of text editors/viewers.
    Andreas
