  3. ADE-L simulation problem
  • Views 19273
gonsays1
gonsays1 over 11 years ago
I've been designing a Two-stage CMOS OTA folded cascode amplifier and now I'm simulating the circuit, in order to get the values of certain parameters (slew-rate, small signal gain, bandwidth, phase margin and GBW product).
The first image is the simulation bench, the second image is the schematic of the Amplifier2 symbol and the third image are the properties of the MOS transistors.
First test:
I've started to simulate the circuit on ADE-L using adequated variables for the dimensions of each transistor (as an example: transistor M11 will have width strip and width defined as variable W11 and length as L11).
I've loaded all the variables to the ADE-L and gave them suitable values. On the output, I've used the calculator to get the functions of the referred parameters, getting the following results:
Av=70.85dB
SR=205.3M
Bw=67.47kHz
PM=62.51
GBW=235.9M
Second test:
After getting those results, I've replaced the variables on the transistor properties for exactly the same value used as the variable (as an example you can check the last image: for the transistor M5 on the ADE-L I had L5=0.55u and W5=13.5u - on that image you can see that I've changed L5 for 0.55u, for instance).
After replacing all the variables for their associated value on the simulation I got different values for the parameters (using the same dimensions):
Av=70.82dB
SR=201.5M
Bw=67.12k
PM=56.83
GBW=234M
Problem:
As you can see, it makes no sense using the same dimensions (with and without variables on the transistor properties) and getting different results.
Is there any way to get the "real" results? I mean, the same result for both cases?
The last image shows the properties of the transistors (on the 2nd test - with assigned values), is there any option that should be changed?
Thank you very much in advance! :)
Best Regards,
G
Simulation schematic:
Amplifier2 schematic:
Transistor properties (schematic):
  • Tom Volden
    Tom Volden over 11 years ago
    The most likely cause of the differences in simulation results is that in the case where you are putting the fixed values in the schematics the callbacks associated with those parameter are being executed.  This means that secondary parameters such as source/drain diffusion areas and peripheries are updated when you change the length and width values.  When using design variables only the length or width value is changed by the parameter since they are inserted at simulation time and the simulator doesn't know about the PDK callbacks.
    So to answer your question, the "real" results are those from your second case where you have fixed values in your design.  You can also achieve these identical results if you use parameterization in ADE XL as this flow triggers the callbacks when updating parameter values prior to netlisting.
    TOM
    I would in general say that this is indicative of a poorly designed PDK - if using design variables it gives incorrect results, then that is really a fault of the PDK. However, as Tom points out, the callback handling in ADE XL can compensate for this.
    ShawnLogan over 11 years ago
    Dear Goncalo,
    Tom and Andrew are both correct - as usual. I have experienced this many times with our PDK and have spoken to our PDK designers.
    If you are looking to achieve simulation repeatability on the order of 1% in a schematic based simulation (as from your GBW product differences), my personal recommendation is that you create a physical layout of the specific circuit and simulate its performance using the resulting extracted view. In a schematic based simulation, effects such as the actual parasitics to the gate, gate-drain capacitances due to surrounding features, trace resistances/capacitances, and MOS stress related parameters are only "best guess" estimates. As a result, it is not uncommon to observe differences between schematic and extracted view simulation results that far exceed 1%. Hence, my thought is, to avoid you attempting to "over optimize" your schematic design and use your valuable time doing so, request a physical layout and perform optimization using the resulting extracted view. You may also be interested in Cadence's electrically aware design flow that provides a more real time view of parasitics in real time during physical layout.
    Of course, please use your best discretion concerning my thoughts!
    Shawn
  • gonsays1
    Thank you all very much!!
    Just a quick question out of the scope of this thread, but regarding the OTA circuit.
    The calculation of the slew-rate is given by SR=Iout/CL? Or in this two-stage amplifier I must use another formula?
    Dear Goncalo,
    I may not be understanding your question completely - and apologize if I am not! My personal thought is that you need to measure the slew rate of the output waveform in a transient simulation in lieu of relying on the formula to assure an accurate slew rate estimate.
    Why is this my thinking?
    The "formula" you provide assumes that the output impedance of the feedback amplifier can be modeled as an ideal current source with value Iout. In reality, the amplifier  possesses a finite output series resistance, and the output resistance will be a function of the output voltage (node "out"). For example, as the voltage of "out" approaches your VDD, the folded cascode pmos current source will have a reduced output impedance and reduce the gain of "amplifier2" significantly and, I assume, increase the output series resistance of its model relative to lower "out" voltages (and ehnce change Iout). I do not know at what output voltage level you are most concerned with measuring the slew rate - and hence this change in output current with output voltage might be significant. By measuring the output slew rate in a transient simulation, my thought is that you can better estimate the slew rate over the specific output voltage range you are interested.
    I hope I understood your question and my thoughts make sense to you.
    Shawn
