  3. ncverilog generate verilog netlist from schmatic
  • Views 18376
chqian
chqian over 9 years ago
when I use ncverilog generate verilog netlist from schmatic, It does not generate the one that contained functional view.
verilogSimStopList =
'("verilog" "pld_verilog" "lai_verilog" "lmsi_verilog" "symbol" )
verilogSimViewList =
'("behavioral" "functional" "system" "verilog" "pld_verilog" "lai_verilog" "lmsi_verilog" "schematic" "symbol" )
simVerilogLibraryDirectory = ""
vlogifCompatibilityMode = "4.0"
 I do not why this happen.
Thanks.
Mike
    Duplicate of
    chqian
    can not generate functional view using nc-verilog
    When I use cadence generate verilog model for top simulation open a schematic , open ade L, choose Launch ->Plugins->Simulation->NC-Verilog the schematic had sub cells which have 'shematic view' '…
    By chqian over 9 years ago in Cadence Technology Forums > Custom IC Design
    1 reply
    Latest by Andrew Beckett over 9 years ago
    Not sure why you asked twice (it's not likely to get answered more quickly by doing that!)
  • chqian
    In fact I can get the netlist , you can see I add vlogifCompatibilityMode = "4.0", in my .simrc since I use IC51, my problem is I can not get down to "functional view",
    the "functional view" had been considered as stopping view , but in "verilogSimStopList" I donot include "functional view" as you can see.
    Is there anything that overwrite my setting during ncverilog generate netlist? Can it be "CDS_LOAD_ENV CSF" or sth. like this.
    Mike
    This is why we ask you not to post twice. I answered this in the other thread, and so the answers now will get scattered between the two threads.
    In IC5141 the only way to get a combined netlist is to use the vlogIfCompatibilityMode="4.0" switch. When I just tried that, it did include the functional views in the combined netlist (sorry - I thought that it didn't).
    Which IC5141 subversion are you using? I'm using the final version 5.10.41.500.6.151 . Does the functional view get mentioned in the verilog.inpfiles (if you have the compatibility mode set to "4.2")?
    If it doesn't, then it may be that the functional view doesn't have the "shadow" database to aid netlisting. Try opening it for edit inside Virtuoso, add a blank line, save and exit and see if the Verilog parser kicks in - you should see a "verilog.cdb" file getting created inside the functional view.
