  3. import physical verilog netlist in Virtuoso
  • Views 28494
oAwad
oAwad over 9 years ago
I generated a physical verliog netlist for my design in Encounter using "saveNetlist design.v -phys -includePowerGround -includePhysicalInst". Here is the explanation of every attribute in this command:
-phys: Writes out physical cell instances, and inserts power and ground nets in the netlist. This is used for LVS and for designs with multiple supply voltages.
-includePowerGround:    Includes power and ground connections in the netlist file.
-includePhysicalInst:   Includes physical instances, such as fillers.
WhenI try to import this netlist in Virtuoso, I get these warnings for all std cells:
WARNING (VERILOGIN-111): Cannot connect the terminal VDD in symbol AOI211_X1 as it does not have a pin.
WARNING (VERILOGIN-111): Cannot connect the terminal VSS in symbol AOI211_X1 as it does not have a pin.
WARNING (VERILOGIN-551): Number of pins on symbol DFF_X2 in library NangateOpenCellLibrary differ from the number of ports in
the HDL module description.
When I open the symbol of DFF_X2, there is no VDD and VSS symbol, so should I update the symbol of all std cells manually to have the VDD and VSS symbols ?
(I can find "VDD!" and "VSS!" pins in DFF_X2 schematic but not in its symbol)
Additionally, I get these warnings for FILLER cells:
WARNING (VERILOGIN-72): Could not find the symbol master for the instance FILLER_5. Therefore the functional
view will not have this instance.
And again there is no symbol view for FILLER cells in the std cell library.
Since, all std cells schematics have VDD! and VSS! pins but their symbols don't, was this made so that Virtuoso power these pins virtually without an explicit power source and ground ? or this is wrong and I have to update all symbols manually ?
Finally, power and ground are called "VDD" and "VSS" respectively in my verilog netlist, however they are written as "VDD!" and "VSS!" in all std cells schematics. So what is the difference between "VDD" and "VDD!" ?
    OK, first thing to consider is whether you actually have multiple powers and grounds. This symbol library (from the look I've had at it) isn't designed to support multiple powers and grounds; each schematic has a global power and ground called VDD! and VSS! (in Virtuoso, global signals are typically suffixed with an exclamation mark). That means that all the powers and grounds in the standard cells themselves do not have distinct connections. There are pins (with global names) on the schematic, but not on the symbols.
    If you don't have multiple powers and grounds on the physical implementation side, don't use the -includePowerGround. Maybe you don't need -phys wither.
    If you don't have symbols for the filler cells, I suggest you omit the -includePhysicalInst.
    If you do have multiple powers and grounds in the design, the best way to achieve this is to edit the schematics for the standard cells. You'll need to do this for all of them (bear in mind they weren't designed for this use model, so it's a bit of work - although not too painful).
    1. Edit the VDD! pin and change the name to VDD. You'll find probably there's a small (blue) text label next to the pin that also renames from VDD! to VDD. Remove this label.
    2. Do the same for VSS! - change that to VSS and remove the VSS label.
    3. Use Create->Net Expression and fill in the property as VDD and default value as VDD!. Then click on the VDD pin
    4. Do the same for the VSS pin (property VSS, default value VSS! and click on the VSS pin)
    5. Check and save the schematic
    Now, when you do an Import Verilog (I don't know which version you're using - this is for IC617), go to the Schematic Generation Options tab and expand the "Reference Schematic View for Inherited Connections". In the List of Views field that appears, enter "schematic". In IC616 it's on the same tab, but is called Reference Schematic Views and is about three-quarters of the way down the form.
    Then what will happen is that when you import the Verilog, it will see that the instance in the Verilog has VDD and VSS pins, and it will then look for these pins in the reference schematic view and instead of connecting up a pin, it will add a netSet property on the instance to connect the power connections using inherited connections.
  • oAwad
    Hello Andrew,
    Thank you for your reply. I can't find any VDD or VSS in the exported verliog netlist without any attributes ("saveNetlist design.v"), so I don't know if this will be ok in verilog import in Virtuoso.
    I'm using IC614 (sorry for being outdated). Here is my .ihdlParamFile:
    DirLabel =/root/Desktop/AES128bits/encounter
    Target Library = NangateOpenCellLibrary
    Reference Libraries =NangateOpenCellLibrary
    Verilog Design Files = design.v
    -y Options =
    Library Extn. =
    -v Options =
    -f Options =
    Ignore Modules File =
    Import Modules File =
    Log File =./verilogIn.log
    Work Area =/tmp
    Power Net =VDD!
    Ground Net =VSS!
    Global Signals =
    Net Expression Property Name for Power Net =vdd
    Net Expression Property Name for Ground Net =gnd
    Create Net Expression =false
    Connect By Name Nets =
    Import Modules That Match Existing Target Library Cells =false
    Verilog Cell Modules =Create Symbol Only
    Verilog Structural Modules View =schematic
    Functional View Name =functional
    Netlist View Name =netlist
    Schematic View Name =schematic
    Symbol View Name =symbol
    Name Map Table = ./verilogIn.map.table
    Sheet Size =none
    Pin Placement Flag =Left and Right Sides
    Pin Placement File =
    Label Size =0.062500
    Maximum Number Of Rows =1024
    Maximum Number of Columns =1024
    Line-Line Spacing =   0.20000
    Line-Component Spacing =   0.50000
    Density Level =0
    Full Place and Route =true
    Fast labels =false
    Minimize Cross Over =false
    Generate Square Schematics =true
    Extract Schematics =true
    Ignore Extra Pins =false
    No Dummy Nets In Netlist View =false
    Verbose =false
    Generate Snap Space Properties =true
    Through CellView Library =basic
    Through CellView Cell =cds_thru
    Through CellView View =symbol
    Continuous Assignment CellView Library =basic
    Continuous Assignment CellView Cell =patch
    Continuous Assignment CellView View =symbol
    Pre Compiled Library =
    Destination IR Lib =
    ViewName for IR Library =hdl
    Only Compile a Verilog Library =false
    Can you tell me what to change ?
    Do you need to change anything? There's generally no need to have power in the verilog if there's only one set of supplies. The supply connections are defined as globals within the standard cells; there's no need for them to be mentioned in the Verilog in that case (in general digital designers are concerned about the signal flow, not the supplies).
    The symbols don't have supplies on them in the library, so nothing needs to be connected up.
    It's unclear to me if anything isn't working for you if you import the Verilog which doesn't contain power/ground information. I'd expect that to work... if it doesn't, you'd need to explain what doesn't work.
  • oAwad
    Hello Andrew,
    I imported the verilog netlist with no attributes ("saveNetlist design.v") with no errors. But when I perform Calibre LVS check, I get errors for every cell stating that the cell in layout have power and ground ports while that in schematic don't.
    Error: Different numbers of ports (see below).
    Error: Power net missing in source. Ground net missing in source.
    I want to run LVS in order to run Calibre PEX after wards to get the SPICE netlist and do post-layout simulations.
    Should I edit all std cells in the library to have power and ground pins in their symbols and them import the verilog netlist using "saveNetlist design.v -phys -includePowerGround -includePhysicalInst" ?
    I very much doubt that you need to edit the standard cells to add these pins to each symbol (and schematic). Having standard cells without power pins is pretty common.
    This is really far beyond what can reasonably be supported in a community forum (especially as you're asking about LVS with a non-Cadence tool that I don't have access to). Do you have a supervisor at your University that can help?
