  3. How to change use clock on nets?
  • Subscribers 92
  • Views 15905
spach
spach over 15 years ago
     I used CTS to buffer signal nets in my design at place stage. once the buffering was over I loaded the actual CTS spec and proceed furthur but these nets r having use clock property. Now My design is fully routed, Can any one tell a procedure to change use clock property to signal for these nets.
suresh
  • BobD
    BobD over 15 years ago
    You may want to consider the "bufferTreeSynthesis" command instead of using CTS.  It build balanced buffer trees without faking the tool out into thinking the net is a clock.
    That said here are a couple of approaches to relieve the clock property on these nets:
    For each of the nets, use dbSet to set the "isCTSClock" bit to 0.  For example:
    dbSet [dbGet -p top.nets.name *clk*].isCTSClock 0
    If you're using an older version of Encounter where isCTSClock isn't an exposed dbGet field you could do the same with older FE-TCL style commands:
    foreach net $netList {
      dbSetIsNetDefInClock $net 0
    Great question!  Let us know how it goes.
    Hope this helps,
    Bob
  • spach
    Hi Bob,
    thank u for u r reply.
    I am working on a hierarchical design. I need to do buffering on nets across partitions. i have written some db scripts to get startpin and corresponding endpn and used cts spec as shown below(no need of balancing b/w nets). i preffer CTS than BTS as CTS takes less run time.
    AutoCTSRootPin core/*/startpin
    SetDPinAsSync YES
    RootInputTran  100.0ps
    MinDelay       300.0ps
    MaxDelay       800.0ps
    MaxSkew        250.0ps
    SinkMaxTran    100.0ps
    BufMaxTran     100.0ps
    Buffer         BFX71
    NoGating       NO
    LeafPin
    + core/*/endpin
    once it was over i cleared the spec. and read the actual clock spec.
    i need to find all nets created by above CTS and change its property to signal.
    suresh
  • spach
    Hi Bob.
              I inserted clock buffers on some clk nets using ecoAddRepeater, but the new nets after the buffer insertion r not getting the use clk property. can u please tell how i can replicate the clk property for new nets also. Also can u please explain how encounter usually assigns this clock property on nets. please reply as soon as possible.
    suresh
  • BobD
    This blog entry on clock net markings might be helpful.
    /blogs/di/archive/2008/08/20/understanding-clock-net-markings-in-soc-encounter.aspx
    There's some good comments there too about nuances related to clock net markings.
    If you load a clock tree spec file and trigger a trace you might be able to get CTS to re-apply the markings.  Another approach is to write the clock tracing to a file, parse it, and apply the clock net markings for each net in the file.
    Hope this helps,
    Bob
  • spach
    Hi Bob,
                   I loaded the clokspec and used the following cmd
    ckSynthesis -check -forceReconvergent -trace
    the property on the eco nets in the clk path not updated. but the report file after tracing contains these eco net names.
    can u please tell how to set clock propery on these nets?
    Regards
    suresh
  • BobD
    Use:
    dbSet [dbGetNetByName <net_name>].isCTSClock 1
    I'll do some testing to see if there's a way to get CTS to automatically trigger the markings based on what it traces.  I'll let you know what I find.
    -Bob
