  3. Fixing max transition violation
  • Subscribers 94
  • Views 23797
mwhite
mwhite over 15 years ago
 We get  max transition violations after RC extraction analysis.  They don't show up during P&R optimizations.  All of the violation nets are high buffer nets but not clocks.  One is a reset and the others are not clock or reset.  The violating nets don't necessarily have the highest fanout.
I read in the Forum that it may not be the best to insert high buffer trees on these nets.  What will be the best way to fix this?
Thanks!
  • Kari
    Kari over 15 years ago
     For high-fanout nets like resets, etc. I would definitely recommend building a buffer tree. You can use bufferTreeSynthesis, or add them in to your .ctstch file and have it done along with the clocks. For non-high-fanout transition violations that only show up after extraction (you didn't say if this was signoff extraction vs native), it could be a scale factor issue. Or, you could have some congested areas in the design. During opt, when added buffers are not yet legally placed, the timing is fine - but after a refinePlace, the cell has to be moved far away, resulting in a transition violation. Visually check the net and see if you can tell what's happening.
  • mwhite
     Hi Kari,
    Thank you for quick answer.
    They are all high fanout transition nets but not necessarily the highest.  We don't have any max_fanout set for the design.  I thought this might be an option for fix, what do you think?
    We are using VDIO license and can only run TQRC within the Encounter tool.  Right now we are planning to use it for sign-off as our design is relatively small and simple with 90nm technology.  We are using the QRC techfile provided by the foundry for RC extraction.  Do you see any issue with our flow?
    At this moment, buffer trees are added only to clocks.  I read somewhere in the forum that it might be better to let the tool to do high net buffer optimization than building high buffer net trees even on reset.  Why is it so?  For power?
    Thank you!
  • Kari
    Kari over 14 years ago
     You can try fixing max fanout and see if it helps. Use "setOptMode -fixFanoutLoad true" after adding a max fanout constraint to the SDC file.
    Letting the tool buffer high-fanout nets or building trees for them is a designer preference. Some designs work best with one method, some with the other.
