  3. Voltus power analysis
  • Subscribers 94
  • Views 18022
kenambo
kenambo over 9 years ago
Hi All,
        I have a whole design of test chip which has analog block as a hard macro. While trying to do power analysis of the whole design, I got an error for the included macro.
I think it is because of the input file required. It requires spice subcircuit file. Is this extracted netlist? or some other thing. Please clarify.
And the power pin for which I am going to analyze power is in Macro level only It is not connected to any top level pins. So is it possible to do power analysis for this macro in VOLTUS environment?
If it is possible How can I do this?
Thanks.
  • Kari
    Kari over 9 years ago
    i'm not really sure if i understand your question. if you want to analyze power inside the macro, you should probably do that at the macro level. if you are analyzing at the test chip level, and don't really care about the macro, then you can make a basic model for the macro that uses the LEF and you won't need the spice for it.
  • kenambo
    Hi Kari,
         Yeah I want to analyze it in test chip level not in macro level. The scenario is I want to analyze the macro which is embedded in the test chip level. So to do this I need spice subcircuit file right?
    My question is what does this spice subcircuit file stand for? Is it extracted spice netlist of the macro? or anything else? Hope my question is clear. I just need to make sure the input files to analyse the macro power grid.
  • Kari
    so it sounds like you want to analyze the design flat. I don't have experience doing this with analog macros. I think you can either analyze flat (not sure what data you need for the analog piece) or you can create a power-grid-view of the analog macro to use while analyzing the top-level. I *think* Voltus-Fi is what is used to create a PGV of the analog macro, but as I said, I don't have experience in this area.
