  2. Functional Verification
  3. please help on verilog and vhdl combination problems
  • Replies 7
  • Subscribers 67
  • Views 16959
victorhan
victorhan over 12 years ago
Hi Candence,
I met a problem in using verilog and vhdl:
1) I use verilog to make a testbench while the DUT all are made by VHDL
2) I want to initialize the lower level memories in DUT. I have tried to use $nc_mirror, but it seems useless.
So would you like to give me some suggestions on how to initial memories in VHDL designs through  verilog testbench?
Thanks!
  • shalem7
    shalem7 over 12 years ago
    I think we can only do this sort of initializing [vhdl DUT,verilog testbench and vice-versa]by using $nc_force and $nc_release.You can try this.
     Please correct me if I am wrong.
    Shalem
  • victorhan
    Thanks for your kindly reply. It works by using $nc_force.
    BTW, how can I transfer a integer variable from verilog to VHDL?
    As the code shows bellow:
    tb_top is verilog module;
    vhdl_top and bellows are vhdl module.
    module tb_top;
    integer i;
    $nc_force("tb_top.vhdl_top:ocmem:memarry[i]" , #data[i]);
    endmodule
    The ERROR message is:
    expecting a integer index i.
  • shalem7
    I am not sure about the error.I did not inderstand the # in #data[i].
    data[i] also needs to be in  " ".
    nc_force command has to be like this.
    If your memarray is of size 5,each single bit
    $nc_force("tb_top.vhdl_top:ocmem:memarry" , "10010"); //if it is a single bit.
    Shalem
  • victorhan
    The important thing is not about how to use #data[i].
    It's how transfer a integer i from the top file in verilog to the inner module writen by VHDL.
    At test bench top file which was written in verilog:
    integer i;
    for (i=0, i < 4096, i=i+1) begin
    $nv_force("tb_top.arcsys:ocram:aram:now:mem_int[i]","#data[i]","verbose");
    end
    The array mem_int is beneth vhdl designed module, so my question is how can I transfer
    the integer i to VHDL designed module mem_int?
  • TAM1
    TAM1 over 12 years ago
     I believe the problem is that you are passing the index into the $nc_force command as a variable rather than a constant. The task is expecting a string with the name of a signal. It isn't going to parse that name and do variable substitution in it. You need to do that yourself.
    Try something like this:
    integer i;
    reg [72*8:1] targetname, srcname;
    initial
      $swrite(targetname,"tb_top.arcsys:ocram:aram:now:mem_int[%0d]",i);
      $swrite(srcname,"#data[%0d]",i);  // I'm not sure exactly what #data refers to, but we're not talking about that...
      $nv_force(targetname,srcname,"verbose");
    end
  • victorhan
     Hi TAM,
    I have tried the method that you told me.
    But it's still useless, the variable i still can't be transfered from verilog top file to the deep VHDL.
    Shaonan
  • TAM1
     I put together a small example and this code appears to work:
       reg [7:0] data [31:0];
       integer i;
       reg [72:1] destname;
       reg [7:0] dataval;
        for ( i=0; i < 32; i=i+1 ) data[i] = i;
        begin
          $swrite(destname,"s1:mem(%0d)",i);
          dataval = data[i];
          $nc_deposit(destname,"#dataval");
        end
    You may want to use $nc_deposit rather than $nc_force if you want to later be able to write to the memory later from inside the VHDL model.
